0254-49
    GREENLEECOMMUNICATIONS(格林利)
    HEX KEY T-HANDLE 1/4" 75"
0254-49 数据手册
WRENCH,T-HANDLE,1/4" T-Handle Wrench, 1/4 Cat No: 0254-49 UPC No: 783310135074 Description • • • • • • • Heat-treated and tempered for extra strength and durability Exceeds ASME/ANSI specifications Ergonomic molded grips formax torque & comfort Ball end allows up to 30 degrees misalignment Square-cut end for high torque applications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • Handle Type : T-Handle, Ergonomic Molded Grips Overall Length : 7-1/2 IN (19.100 CM) Size : 1/4 IN Standard : ASME/ANSI Type : Hex Key Driver Weight : 0.250 LB (0.110 KG)
0254-49 价格&库存
很抱歉,暂时无法提供与“0254-49”相匹配的价格&库存,您可以联系我们找货
