167/8
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE 24AWG YELLOW
167/8 数据手册
WIRE FERL INSUL Insulated Wire Ferrules Cat No: 167/8 UPC No: 783310029748 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Light Yellow Color Code : French Standard Dimension Inches L2 : 0.315 IN (8.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K1GL, K32GL, K30GL, Die 03283 Size : 0.511 IN (13.000 MM) Overall Length, 0.315 IN (8.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 24 AWG (0.250 SQ-MM) Wire Type : Stranded
167/8 价格&库存
很抱歉,暂时无法提供与“167/8”相匹配的价格&库存,您可以联系我们找货
