PA3596
PA3596
    TEMPOCOMMUNICATIONS
    Punchdown 110 Blade, Light
PA3596 数据手册
PUNCHDOWN - SSP W/110 SurePunch Pro PDT with 110 reversible cut & punch/punchonlyblade and light Cat No: PA3596 UPC No: 769328110418 Description • • • • • • • • • Terminate cable in single punch - including 23 AWG Cat6 Detachable light with long-life LED specially designed to focus the light on the panelwork area Luminous intesity of the LED is 2200 mcd Finger grips and non-slip rubber-embedded cushioned handle for comfort Multi-use spudger that canbe used as a screwdriver or an IDC contact insertion tool Hook to feed wires throughholes Pick to separate bonded twisted-pair cables or to strip insulation and cut wire Adjustable HI/LO spring compression for all cable types.LO= 27.5 lbs (122 N), HI= 37.5 lbs (167 N) Uses twist-and-lock style blades10~ Blade storage area in endof handle with comfortable latch cover Specifications • • Includes : 110 Reversible Cut And Punch/Punch-Only Blade And Light Sub Brand : SurePunch Pro
PA3596 价格&库存
很抱歉,暂时无法提供与“PA3596”相匹配的价格&库存,您可以联系我们找货
