04030644
    ICOMTECH
    IOLAN TS2 TERMINAL SERVER: 2 X R
04030644 数据手册
IOLAN DG1 and TG2 Device Servers perle.com/products/iolan-dg-device-server.shtml Serial to Ethernet Device Servers 1 or 2 serial Ports Software selectable RS232/422/485 or fixed RS232 serial port interface 10/100 or 10/100/1000 Ethernet Extended temperature model available The IOLAN DG/TG Device Server is the best choice for simple serial to Ethernet connectivity applications. Delivering a cost effective solution in a compact size, the IOLAN DG/TG offers flexibility and advanced TrueSerial® technology making it ideal for applications that require an authentic serial connection across an Ethernet network. IOLAN DG1 Device Servers are also available with support for Extended Temperature Ranges. IOLAN Device Server Features and Benefits TrueSerial® delivers the most authentic serial connections across Ethernet Powerful processors for the best throughput and performance on the market Indicators for network and serial interfaces for easy troubleshooting Plug & Play installation utility eliminates configuration hassles for all IOLANs on you IP network TruePort software provides true remote serial ports over an Ethernet LAN Share a serial port with multiple TCP or UDP servers Software Development Kit available to develop powerful custom applications Power over serial cable models eliminate costs of a separate power installation Next Generation IP support (IPv6) for investment protection and network compatibility Compact and protective solid steel enclosure for tabletop, wall mount or DIN rail mounting Flexible and Reliable Serial to Ethernet Connections The IOLAN DG/TG is ideal for connecting serial-based COM port, UDP or TCP socket based applications to remote devices. Perle’s TruePort redirector provides fixed TTY or COM ports to server based applications enabling communication with remote devices connected to Perle device servers. You can also tunnel serial data between devices across an IP network. Easy to set up and manage, the IOLAN has a software selectable RS-232/422/485 interface capability which simplifies setup and eliminates mechanical tampering associated with DIP switch based products. 1/12 Perle’s Device Management software, shipped as standard with the IOLAN DG/TG, provides better centralised control and management of multiple units resulting in maximum uptime for your remote equipment. Protection against electrostatic discharges and power surges is provided on the IOLAN DG/TG with its robust 15Kv ESD protection circuitry enabling organizations to utilize this solution with confidence. IOLAN Device Server Plug-ins Backed with the experience of connecting hundreds of thousands of different devices to Ethernet over the years, using a Perle Device Server you can rest assured that virtually any device with a serial COM port will operate in conjunction with your desired application exactly as it did when you had it directly connected. If the unlikely event occurs that the Perle Device Server does not enable this out of the box, Perle will make it work. Perle IOLAN Device Servers utilize customer installable “Device Plug-ins” to successfully network devices where other solutions have failed. Request a free engineering consultation now. Advanced IP Technology With support for Next Generation IP (IPv6) the IOLAN range provides organizations with investment protection to meet this rapidly growing standard. Demand for IPv6, which is compatible with IPv4 addressing schemes, is driven by the need for more IP address. With the implementation and rollout of advanced cellular networks, a robust method is needed to handle the huge influx of new IP addressable devices on the Internet. In fact, the US Department of Defense has mandated that all equipment purchased be IPv6 compatible. In addition, all major Operating Systems such as Windows, Linux, Unix and Solaris, as well as routers, have built-in support for IPv6. It is therefore important for end users and integrators to select networking equipment that incorporates the IPv6 standard. The IOLAN line with support for IPv6 already built in, is the best choice in serial to Ethernet technology. Lifetime Warranty The Perle IOLAN DG/TG Device Server is backed by the best service and support in the industry including Perle’s unique lifetime warranty. Since 1976 Perle has been providing its customers with networking products that have the highest levels of performance, flexibility and quality. Software Features - IOLAN DG1 & TG2 Device Server Serial Port Access Connect directly using Telnet and Reverse Telnet Multihost access enables multiple hosts/servers to share serial ports Accessibility In-band ( ethernet ) and out-of-band ( dial-up modem ) support 2/12 IPV6 and IPV4 addressing support Availability Primary/Backup host functionality enables automatic connections to alternate host(s) Security Local database USERID/PASSWORD Disable unused daemons Terminal Server Telnet Auto session login MOTD - Message of the day Serial machine to Ethernet Tunnel raw serial data across Ethernet Raw serial data over TCP/IP Raw serial data over UDP Serial data control of packetized data Share serial ports with multiple hosts/servers Virtual modem simulates a modem connection - assign IP address by AT phone number TruePort com/tty redirector for serial based applications on Windows, Linux, Solaris, SCO, HP UX, NCR UNIX and AIX. For a complete list of all the latest drivers click here "TrueSerial packet technology provides the most authentic serial connections across Ethernet ensuring serial protocol integrity" RFC 2217 standard for transport of serial data and RS232 control signals Customizable or fixed serial baud rates Plug-ins allow customer or Perle provided plug-ins for special applications Software Development Kit ( SDK ) available Serial encapsulation of industrial protocols such as ModBus, DNP3 and IEC-870-5-101 3/12 ModBus TCP gateway enables serial Modbus ASCII/RTU device connection to ModBus TCP Data logging will store serial data received when no active TCP session and forward to network peer once session re-established - 4K bytes circular per port Console Management Sun / Oracle Solaris Break Safe Reverse Telnet OA&M ( Operations, Administration and Management ) SNMP V3 - read and write, Perle MIB Syslog Perle Device Manager - Windows based utility for large scale deployments Configurable default configuration Installation Wizard Set a Personalized Factory Default for your IOLANs Protocols IPv6, IPv4, TCP/IP, ARP, RARP, UDP, UDP Multicast, ICMP, BOOTP, DHCP, TFTP, Telnet, raw, reverse Telnet, WINS, HTTP, SNMPV3, RFC2217 Hardware Specifications - IOLAN DG1 & TG2 Device Servers IOLAN DG1 Processor IOLAN TG2 600Mhz ARM Processor Memory RAM MB 512 Flash MB 4000 Interface Ports Number of Serial Ports 1 2 Serial Port Interface Software selectable RS-232/422/485 on DB25F, DB9M or RJ45 RS-232 on RJ45 - 10 pin 4/12 Sun / Solaris Sun / Oracle ‘Solaris' Safe - no "break signal" sent during power cycle causing costly server re-boots or downtime Serial Port Speeds 300bps to 230Kbps with customizable baud rate support Data Bits Configurable for 5,6,7 or 8-bit protocol support Use TruePort to transparently pass 9-bit serial data Parity Odd, even, Mark, Space, None Flow Control Hardware, Software, Both, None Serial Port Protection 15Kv Electrostatic Discharge Protection (ESD) Local Console Port RS232 on Serial Port Network Autosensing 1000Base-T / 100Base-TX / 10Base-T AutoMDIX Software selectable Ethernet speed 10/100/1000 Software selectable Half/Full/Auto duplex Ethernet Isolation 1.5Kv Magnetic Isolation Power IOLAN DG1 Power Supply 120 V AC (USA), 230V AC (International) Wall Power Adaptor included Power Supply Options Power via External power 9-30v DC, 4.8 Watts uses standard 5.5mm x 9.5mm x 2.1mm barrel socket Power IN over serial cable YES Nominal Input Voltage 12v DC / 24v DC Input Voltage Range 9-30v DC Typical Power Consumption @ 12v DC (Watts) 1.9 IOLAN TG2 On Port #1 2 Indicators LEDs Power / Ready Network Link Network Link activity 5/12 Serial: Transmit and Receive data per port Environmental Specifications IOLAN DG1 IOLAN TG2 Heat Output (BTU/HR) 6.8 8.9 MTBF (Hours) 267,483 254,834 Calculation model based on MIL-HDBK-217-FN2 @ 30 °C Operating Temperature 0ºC to 55ºC (32ºF to 131ºF) Storage Temperature -40ºC to 66ºC, (-40ºF to 150ºF) Humidity 5 to 95% (non condensing) for both storage and operation. Case SECC Zinc plated sheet metal (1 mm) Ingress Protection Rating IP40 Mounting Wall or Panel mounting . DIN Rail mounting kit optional Product Weight and Dimensions Weight .23 KG (.51 lbs) Dimensions 90 x 64 x 22 (mm), 3.6 x 2.5 x 0.87 (in) case dimensions not including mounting tabs 90 x 89 x 24 (mm), 3.6 x 3.5 x 0.87 (in) includes mounting tabs. Packaging Shipping Dimensions 260 x 170 x 70 (mm), 10.2 x 6.7 x 2.8 (in) Shipping Weight 0.49 KG (1.1 lbs) Regulatory Approvals Emissions CFR47 FCC Part 15 Subpart B:2015 ICES-003:2016 Issue 6:2016 CISPR 32:2015/EN 55032:2015 (Class A) EN55011 (CISPR11) CISPR 16-2-3:2010/A2:2014 6/12 EN61000-3-2:2014, Limited for Harmonic Current Emissions EN61000-3-3:2013, Limits of Voltage Fluctuations and Flicker Immunity CISPR 24:2010/EN 55024:2010 EN61000-4-2: 2009 Electrostatic Discharge EN61000-4-3: 2006/A2:2010: RF Electromagnetic Field Modulated EN61000-4-4: 2004 Fast Transients EN61000-4-5: 2006 Surge EN61000-4-6: 2009 RF Continuous Conducted EN61000-4-8: Power-Frequency Magnetic Field EN61000-4-11: Voltage Dips and Voltage Interruptions Safety IEC 62368-1 and EN 62368-1:2014 CAN/CSA-C22.2 No. 62368-1-14 and UL 62368-1 Other Reach, RoHS and WEEE Compliant ECCN - 5A991 HTSUS Number: 8517.62.0020 Perle Lifetime warranty IOLAN DB9M Serial Connector Pinout DB9M Socket Pinout Direction EIA232 EIA-422 Full Duplex EIA-485 Full Duplex 1 in DCD 2 in 3 4 RxD RxD+ RxD+ out TxD TxD+ TxD+ DATA+ out DTR GND GND GND GND DSR RxD- RxD- 5 6 in EIA-485 Full Duplex 7/12 7 out RTS 8 in CTS 9 TxD- TxD- DATA- IOLAN DB25F Serial Connector Pinout DB25F Socket Pinout Direction 1 EIA-232 EIA-422 EIA-485 Full Duplex EIA-485 Half Duplex Shield Shield Shield Shield GND GND GND Power In (930V DC) Power In (930V DC) Power In (930V DC) 2 in RxD 3 out TxD 4 in CTS 5 out RTS 6 out DTR 7 8 GND in DCD 9 12 Power In (930V DC) 13 RTS- 14 RxD+ RxD+ 15 RxD- RxD- 18 CTS+ 19 CTS- 20 in DSR 21 TxD+ TxD+ DATA+ 22 TxD- TxD- DATA- 25 RTS+ 8/12 IOLAN RJ45 Serial Connector Pinout for DG1 R J 4 5 S o ck Pinout Direction 1 et EIA-232 EIA-422 EIA-485 Full Duplex Power In (9-30V DC) Power In (9-30V DC) Power In (9-30V DC) Power In (9-30V DC) TxD+ TxD+ TxD+/RxD+ TxD-/RxD- 2 in DCD 3 out RTS 4 in DSR 5 out TxD TxD- TxD- 6 in RxD RxD+ RxD+ GND GND GND RxD- RxD- 7 8 in CTS 9 out DTR EIA-485 Half Duplex GND 10 Optional Perle adapters for use with straight thru CAT5 cabling IOLAN RJ45 Serial Connector Pinout for TG2 RJ45 Socket Pinout 10pin Pinout 8pin Direction 1 EIA-232 Power In (9-30V DC) 2 1 in DCD 3 2 out RTS 4 3 in DSR 5 4 out TxD 6 5 in RxD 9/12 7 6 GND 8 7 in CTS 9 8 out DTR 10 not used Optional Perle adapters for use with straight thru CAT5 cabling Find IOLAN DS1 or TS2 TCP Using RAW TCP Sockets A raw TCP socket connection which can be initiated from the serial-Ethernet device or from the remote host/server. This can either be on a point to point or shared basis where a serial device can be shared amongst multiple devices. TCP sessions can be initiated either from the TCP server application or from thePerle IOLAN serial-Ethernet adapter. UDP 10/12 Using Raw UDP Sockets For use with UDP based applications, Perle IOLANs can convert serial equipment data for transport across UDP packets either on a point to point basis or shared across multiple devices. Console Server Console Management For access to remote console ports on routers, switches,etc, Perle IOLAN’s enable administrators secure access to these RS232 ports via inband Reverse Telnet / SSH or out of band with dial-up modems. Perle IOLAN models with integrated modems are available. COM/TTY Connect Serial-based Applications with a COM/TTY Port Driver Serial ports can be connected to network servers or workstations running Perle's TruePort software operating as a virtual COM port. Sessions can be initiated either from the Perle IOLAN or from TruePort. 11/12 Tunneling Serial Tunneling between two Serial Devices Serial Tunneling enables you to establish a link across Ethernet to a serial port on another IOLAN. Both IOLAN serial ports must be configured for Serial Tunneling (typically one serial port is configured as a Tunnel Server and the other serial port as a Tunnel Client). Virtual Modem Virtual Modem Enables the serial-Ethernet adapter to simulate a modem connection. When connected to the IOLAN and initiates a modem connection, the IOLAN starts up a TCP connection to another IOLAN serial-Ethernet adapter configured with a Virtual Modem serial port or to a host running a TCP application. Copyright © 1996 - 2021 Perle. All Rights Reserved 12/12
04030644 价格&库存
很抱歉,暂时无法提供与“04030644”相匹配的价格&库存,您可以联系我们找货
