DiddyBorg V2 Robot Kit – Purple
Our most popular Raspberry Pi robot kit DiddyBorg is back with faster motors
and a newly designed chassis! The idea remains the same, a 6 wheeled high‐
torque robotics platform, but give everyone the ability to add lots of extra
functionality and get your robot to perform a wide range of tasks.
Want to detect objects in your DiddyBorg's path? Add the ultrasonic mounts at the
front and back. Need to use a servo to move a robotic arm? Mount them on the
multifunction top and go!
You could even add the Raspberry Pi touch screen and turn your robot into a
touchscreen controlled turtle.
A Raspberry Pi B+/2/3/3B+ and SD cardare required to complete your DiddyBorg
v2, they are not included. DiddyBorg v2 optionally supports the Pi Camera, also not
included.
Specifications
Basic DiddyBorg v2 comes with:
Chassis: Laser cut 3mm Cast Acryllic PerspexTM in Purple now designed and cut at
PiBorg.
Six 1:83 (100rpm) metal gear 12V 400mA PiBorg motors.
Our ThunderBorg 5A dual output motor controller including LED indicator, power
regulator and PWM control.
On/Off switch.
Full build instructions.
Code library and example scripts.
There are two additional styles of top available for the DiddyBorg v2:
The Multifunction Top with mounting holes for servos and adaptable mounting
points for an additional Raspberry Pi 3, Raspberry Pi Zero or Zero W or the Arduino
Uno.
The Touch Top which takes the Raspberry Pi 7" touch screen. These can be used in
addition to the basic kit in a number of combinations!
We also have a sensor mounting kitwhich includes mounts for 4x ultrasonics and a
second pi camera.
https://uk.pi‐supply.com/products/diddyborg‐v2‐robot‐kit‐purple 7‐26‐18
很抱歉,暂时无法提供与“PIS-0937”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1582.108471+191.05485
