Neblio StakeBox
StakeBox and?Neblio have partnered together to bring?you the?Neblio StakeBox ‐
a?device that allows you to stake your?Neblio cryptocurrency and make a return on
your investment.?
Staking?Neblio?is the process of securing the network with your coin weight, which
in turn rewards you with new Neblio.
The stakebox?requires little setup allowing you to get up and running in no time at
all and includes all the essential?accessories. Set it up and start earning crypto
rewards* without needing to buy an expensive?computer rig.
What's Inside
Raspberry Pi 3 Model B
Neblio Case
2.5A International Power Supply Unit
16GB SD card with?Neblio software
HDMI cable
Raspberry Pi 3 Specifications
Processor
o
Broadcom BCM2387 chipset
o
1.2GHz Quad‐Core ARM Cortex‐A53
o
o
o
o
o
o
o
802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE)
GPU
Dual Core VideoCore IV? Multimedia Co‐Processor. Provides Open GL ES 2.0,
hardware‐accelerated OpenVG, and 1080p30 H.264 high‐profile?decode
Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and?DMA
infrastructure
Memory
1GB LPDDR2
Operating System
Boots from Micro SD card, running a version of the Linux operating system
or?Windows 10 IoT
Dimensions
85 x 56 x 17mm
Power
Micro USB socket 5V1, 2.5A
*staking interest depends on the specific cryptocurrency and other conditions and is
not guaranteed by StakeBox
https://uk.pi‐supply.com/products/neblio‐stakebox 6‐26‐18
很抱歉,暂时无法提供与“PIS-0638”相匹配的价格&库存,您可以联系我们找货
