Octopus ADKeypad
The Pi Supply Octopus ADkeyboard uses an analog input to read the five key state
which saves IO resource for the Arduino. It can be used together with our I/O
expansion boards to make amazing interactive projects.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Specifications
Supply voltage: voltage controller
Interface: Analog
What’s Included
1 x ADKeypad
1 x Analog Sensor Cable
https://uk.pi‐supply.com/products/octopus‐adkeypad?_pos=1&_sid=7a5f945a8&_ss=r/8‐1‐19
很抱歉,暂时无法提供与“PIS-1284”相匹配的价格&库存,您可以联系我们找货
