BattBorg ‐ Pi Battery Power Board PCB
Only (Soldered)
The BattBorg is a plug and play power converter for your Raspberry Pi which allows
you to power the Raspberry Pi with batteries! It's great for robot projects, or where
you need to leave you Pi unmanned for extended periods without a wired power
source (outside sensor projects etc.)
The BattBorg uses a highly efficient (~90%) OKI78SR DCDC converter which has a
maximum 1.5A output and, due to it's efficiency, requires no heatsink. It will work
with most batteries/battery packs that are between 7‐36V so it's great for 12V car
batteries, 8xAA battery packs, and so on.
BattBorg comes in several different kits. This purchase is for the Soldered BattBorg
PCB (fully assembled), and a 3‐pin cable. You'll need to supply your own battery
pack, then all you need is a Raspberry Pi, and batteries, and you're ready to roll!
BattBorg Features:
Soldered PCB Only Kit Includes:
o
Assembled & Soldered BattBorg PCB
o
3 Pin Cable M/F Cable
Mounting Pillar & Screw
5V 1.5A Max Output
~90% Efficient
Compatible with battery packs (or batteries) between 7V ‐ 36V
Plugs into GPIO Pins 2, 4 & 6
Up to 14 Hours Run‐Time @ 15% Load (8 x AA Batteries)
Compatible with Model A, B, A+, B+, 2, 3, Zero, ZeroW
o
https://uk.pi‐supply.com/products/battborg‐pi‐battery‐power‐board‐pcb‐only‐soldered 7‐26‐18
很抱歉,暂时无法提供与“PIS-0926”相匹配的价格&库存,您可以联系我们找货
