RAKwireless RAK2013 Cellular Raspberry
Pi HAT
The RAK2013 is a Raspberry Pi 3B+ edition cellular communications module that supports
Low-Power Wide- Area (LPWA) technology for networking Internet-of-Things (IoT) devices. It
can support optional BG96 / EG91 / EG95 for 4G/LTE, NB-IoT, CAT-M, CAT1 or CAT 4
cellular protocol. The RAK2013 integrates audio codec and audio amplifier on it, with carrier
operator’s network, it also supports Voice-over-LTE (VoLTE) for high definition (HD) and
uninterrupted voice calls. For easy use, there are earphone connector, MIC connector and
speaker connector with audio amplifier.
It also supports a connector to extend sensor board. The sensor board connector follows
MikroBus standard, MikroBus has many kinds of the sensor board, such as temperature,
humidity, 3 axis sensors, light sensor, etc. It is easy to get sensor data thought MikroBus
interface and can transmit the sensor data through a cellular network to your server.
The RAK2013 can connect to RAK2245 Pi Hat board directly, which is RAK’s LoRa
concentrator module following Raspberry Pi 3B+ edition. It is easy to make a LoRaWAN
gateway by plugging them to a Raspberry Pi board, it can transmit LoRa data to cloud server by
a cellular network.
Package contains
RAK2013 cellular Raspberry Pi HAT
LTE Antenna IPEX
GPS Antenna IPEX (For BG96 only)
microUSB cable
Main Features
Compatible with Raspberry Pi 3B+
Support optional cellular module (Quectel BG96 or EG91 or EG95) for NB‐IOT / CAT‐M / CAT1 LTE / CAT4
LTE.
Supports Voice over CAT‐M or VoLTE.
Supports Nano SIM card or eSIM card.
Integrates audio codec and audio amplifier.
Integrates MikroBus interface to support sensor extended board.
Can be added to another Pi HAT to support LoRa concentrator.
Supports USB connector for higher data rate.
Supports GPS function(only for BG96 module)
SMA/IPEX antenna is optional for LTE and GPS.
Supports I2C, GPIOs, UART and ADC interfaces for Raspberry board.
Supports EEPROM to configure IOs automatically.
Key Features
Cellular Module: Optional Quecteel BG96 or EG91 or EG95
Cellular Standard and Bands
o
With BG96: NB‐IOT/ CAT‐M Cat M1/Cat NB1: LTE FDD:
B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B26/B28 LTE TDD: B39 (For Cat M1 Only); EGPRS:
850/900/1800/1900MHz
o
With EG91: LTE CAT 1 / With EG95:LTE CAT 4
o
Variant for Europe LTE FDD: B1/B3/B7/B8/B20/B28A; WCDMA: B1/B8; GSM: 900/1800MHz
o
Variant for North America LTE FDD: B2/B4/B5/B12/B13; WCDMA: B2/B4/B5
Data Rate
With BG96 Cat M1: Max. 300Kbps (DL), Max. 375Kbps (UL) Cat NB1: Max. 32Kbps
(DL), Max. 70Kbps (UL) EDGE: Max. 296Kbps (DL), Max. 236.8Kbps (UL) GPRS: Max.
107Kbps (DL), Max. 85.6Kbps (UL)
With EG91 LTE: LTE FDD: Max 10Mbps (DL)/Max 5Mbps (UL) UMTS: DC‐HSDPA:
Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps (DL)/Max
384Kbps (UL) GSM: EDGE: Max 296Kbps (DL)/Max 236.8Kbps (UL) GPRS: Max
107Kbps (DL)/Max 85.6Kbps (UL)
With EG95 LTE: LTE FDD: Max 150Mbps (DL)/Max 50Mbps (UL) UMTS: DC‐
HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps
(DL)/Max 384Kbps (UL) GSM: EDGE: Max 296Kbps (DL)/Max 236.8Kbps (UL)
GPRS: Max 107Kbps (DL)/Max 85.6Kbps (UL)
Voice: VoLTE (Cat M1 Only)
SMS: Point‐to‐point MO and MT; SMS Cell Broadcast; Text and PDU Mode
GNSS (optional): GPS(only for module with BG96)
Peripheral Interface:
o
40‐pins Raspberry connector header
o
Micro USB; MikroBus Connector
o
Earphone Jack; MIC Jack; Speaker Jack
o
RESET Button; PWRKEY Button
o
Nano Sim Card slot; USB boot jumper
LED
o
Green: Board Power‐on Indication
o
Blue: Cellular Module Power‐on Indication
o
Red: Networkk Status Indication
Power Consumption
o
Min 10mA in Power off mode
o
Typical 300mA in CAT M mode
o
Max 2000mA in GSM mode
Software
o
o
o
Enhanced AT Commands
Protocol:
PPP/TCP/UDP/SSL/TLS/FTP(S)/HTTP(S)/NITZ/PING/MQTT
Driver Support for Windows, Linux
Physical Dimension
o
Dimension: 65.0 x 56.0 x 19.5 mm (LxWxH,
o
Weight: Approximately 0.99 oz (±0.1oz)
Temperature Range
o
Operation Temperature: ‐35° C ~ +75° C
o
Extended Temperature: ‐40° C ~ +85° C
o
Storage Temperature: 40° C ~ +90° C
Certification: FCC, CE
Hardware interfaces
https://uk.pi‐supply.com/products/rakwireless‐rak2013‐cellular‐raspberry‐pi‐hat?_pos=1&_sid=c1225f3f3&_ss=r/7‐30‐19
很抱歉,暂时无法提供与“PIS-1594”相匹配的价格&库存,您可以联系我们找货
