PIS-1593
PIS-1593
    PISUPPLY
    RAK2013 CELLULAR PI HAT EG95-E
PIS-1593 数据手册
          RAKwireless RAK2013 Cellular Raspberry Pi HAT The RAK2013 is a Raspberry Pi 3B+ edition cellular communications module that supports Low-Power Wide- Area (LPWA) technology for networking Internet-of-Things (IoT) devices. It can support optional BG96 / EG91 / EG95 for 4G/LTE, NB-IoT, CAT-M, CAT1 or CAT 4 cellular protocol. The RAK2013 integrates audio codec and audio amplifier on it, with carrier operator’s network, it also supports Voice-over-LTE (VoLTE) for high definition (HD) and uninterrupted voice calls. For easy use, there are earphone connector, MIC connector and speaker connector with audio amplifier. It also supports a connector to extend sensor board. The sensor board connector follows MikroBus standard, MikroBus has many kinds of the sensor board, such as temperature, humidity, 3 axis sensors, light sensor, etc. It is easy to get sensor data thought MikroBus interface and can transmit the sensor data through a cellular network to your server. The RAK2013 can connect to RAK2245 Pi Hat board directly, which is RAK’s LoRa concentrator module following Raspberry Pi 3B+ edition. It is easy to make a LoRaWAN gateway by plugging them to a Raspberry Pi board, it can transmit LoRa data to cloud server by a cellular network. Package contains   RAK2013 cellular Raspberry Pi HAT   LTE Antenna IPEX   GPS Antenna IPEX (For BG96 only)   microUSB cable    Main Features   Compatible with Raspberry Pi 3B+   Support optional cellular module (Quectel BG96 or EG91 or EG95) for NB‐IOT / CAT‐M / CAT1 LTE / CAT4  LTE.   Supports Voice over CAT‐M or VoLTE.   Supports Nano SIM card or eSIM card.   Integrates audio codec and audio amplifier.   Integrates MikroBus interface to support sensor extended board.   Can be added to another Pi HAT to support LoRa concentrator.   Supports USB connector for higher data rate.   Supports GPS function(only for BG96 module)   SMA/IPEX antenna is optional for LTE and GPS.   Supports I2C, GPIOs, UART and ADC interfaces for Raspberry board.   Supports EEPROM to configure IOs automatically.    Key Features   Cellular Module: Optional Quecteel BG96 or EG91 or EG95   Cellular Standard and Bands   o With BG96: NB‐IOT/ CAT‐M Cat M1/Cat NB1: LTE FDD:  B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B26/B28 LTE TDD: B39 (For Cat M1 Only); EGPRS:  850/900/1800/1900MHz  o With EG91: LTE CAT 1 / With EG95:LTE CAT 4  o Variant for Europe LTE FDD: B1/B3/B7/B8/B20/B28A; WCDMA: B1/B8; GSM: 900/1800MHz  o Variant for North America LTE FDD: B2/B4/B5/B12/B13; WCDMA: B2/B4/B5  Data Rate  With BG96 Cat M1: Max. 300Kbps (DL), Max. 375Kbps (UL) Cat NB1: Max. 32Kbps (DL), Max. 70Kbps (UL) EDGE: Max. 296Kbps (DL), Max. 236.8Kbps (UL) GPRS: Max. 107Kbps (DL), Max. 85.6Kbps (UL) With EG91 LTE: LTE FDD: Max 10Mbps (DL)/Max 5Mbps (UL) UMTS: DC‐HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps (DL)/Max 384Kbps (UL) GSM: EDGE: Max 296Kbps (DL)/Max 236.8Kbps (UL) GPRS: Max 107Kbps (DL)/Max 85.6Kbps (UL) With EG95 LTE: LTE FDD: Max 150Mbps (DL)/Max 50Mbps (UL) UMTS: DC‐ HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps (DL)/Max 384Kbps (UL) GSM: EDGE: Max 296Kbps (DL)/Max 236.8Kbps (UL) GPRS: Max 107Kbps (DL)/Max 85.6Kbps (UL) Voice: VoLTE (Cat M1 Only) SMS: Point‐to‐point MO and MT; SMS Cell Broadcast; Text and PDU Mode GNSS (optional): GPS(only for module with BG96) Peripheral Interface: o 40‐pins Raspberry connector header o Micro USB; MikroBus Connector o Earphone Jack; MIC Jack; Speaker Jack o RESET Button; PWRKEY Button o Nano Sim Card slot; USB boot jumper LED o Green: Board Power‐on Indication o Blue: Cellular Module Power‐on Indication o Red: Networkk Status Indication Power Consumption o Min 10mA in Power off mode o Typical 300mA in CAT M mode o Max 2000mA in GSM mode Software o o o Enhanced AT Commands Protocol: PPP/TCP/UDP/SSL/TLS/FTP(S)/HTTP(S)/NITZ/PING/MQTT  Driver Support for Windows, Linux Physical Dimension o Dimension: 65.0 x 56.0 x 19.5 mm (LxWxH, o Weight: Approximately 0.99 oz (±0.1oz) Temperature Range o Operation Temperature: ‐35° C ~ +75° C o Extended Temperature: ‐40° C ~ +85° C o Storage Temperature: 40° C ~ +90° C Certification: FCC, CE   Hardware interfaces                         https://uk.pi‐supply.com/products/rakwireless‐rak2013‐cellular‐raspberry‐pi‐hat?_pos=1&_sid=c1225f3f3&_ss=r/7‐30‐19
PIS-1593 价格&库存
很抱歉,暂时无法提供与“PIS-1593”相匹配的价格&库存,您可以联系我们找货
