MDBT42Q Breakout ESP004
This board has the same Bluetooth LE module that used
on Puck.js and Pixl.js, pre-programmed with Espruino. Just
apply power, connect with Bluetooth LE or Serial and start
writing JavaScript!
This is a board with 0.1" pins, a voltage regulator, 2 LEDs and a button. It's thin, small,
and very power efficient.
Features
Bluetooth Low Energy
Espruino JavaScript interpreter pre-installed
nRF52832 SoC - 64MHz ARM Cortex M4, 64kB RAM, 512kB Flash
32 x GPIO (capable of PWM, SPI, I2C, UART) on 0.7mm Pitch, including 8 analog inputs
1.7v - 3.6v voltage range
Built in thermometer
NFC tag programmable from JavaScript (when an antenna is connected)
Dimensions: 16mm x 10mm x 2.2mm thick
Breakout board features
2.5 - 16v voltage input, 20uA power draw when advertising
0.1" pin header (With 22 GPIO, 7 analog inputs)
Red and Green LEDs
Button
Getting Started
Apply power between the V+/Vin and GND pins. Any voltage between 2.5 and 16 volts
will work - just be careful not to get the polarity wrong! Check the pinout for more
information on the location of pins.
Once powered up follow the Getting Started Guide for details on getting the IDE
connected wirelessly. You can also use a wired connection if you prefer.
On-board peripherals
There is a button (BTN/BTN1) between pin D0 and 3.3v. Pulling this high on boot enables the
bootloader.
There is a LED (LED/LED1) between pin D1 and GND. This is flashes at boot and also indicates
bootloader mode.
The breakout board also contains a green LED on pin D2. As of build 1v99 this isn't
mapped to a built-in variable, but a simple global.LED2=D2command will add it.
https://shop.pimoroni.com/products/mdbt42q‐breakout 8‐20‐18
很抱歉,暂时无法提供与“ESP004”相匹配的价格&库存,您可以联系我们找货
