MIME 004
MIME 004
    PIMORONI
    MEARM MAKER
MIME 004 数据手册
    MeArm Maker The build-it-yourself robot arm kit The MeArm Maker is an easy-to-build robot arm kit that's designed to get children (and adults!) learning about technology, engineering and programming. It's been expressly designed to be easy to build (age 11+) and use. It comes without the controller, leaving you to supply your own. It's easy to get it working with Arduino, Raspberry Pi, mBed and any other microcontroller platform you can think of (so long as it can control a servo!). The MeArm Maker has been designed from the ground up to be easy to assemble. Children can build it themselves and we suspect adults may be able to build it unaided too. The only tool you'll need to build it is a hex key, and we include one in the box! Included in the box  Plastic parts for the structure of the arm  Socket head screws for easy assembling  Hex key so you don’t need your own tools  4 Metal gear servos  Everything you need to build your MeArm except the controller! Specifications  Bring your own controller  Connect directly to the four servos  4 degrees of freedom  Compatible with Arduino and Raspberry Pi                                                     https://shop.pimoroni.com/products/mearm‐maker 5‐25‐18
MIME 004 价格&库存
很抱歉,暂时无法提供与“MIME 004”相匹配的价格&库存,您可以联系我们找货
