SPECIFICATION SHEET
Customer:
Product: CC26125
Model: 2.6 x 125 | 0.286/0.283
Plazmo Industries
1
Specifications
1. Available Range. The specifications available to CCFL unit listed on page 1.
2. Product Construction.
Item No.
Name
1
Dimension
2
3
4
5
Glass tube
Fluorescent powder
Electrode
Gas
Requirements
Lamp Shape: Straight
Dia: Φ2.6 ±0.1mm
Glass tube length: 125 +/- 1.0mm
Hard material glass tube
Three primary colors phosphor
Kovar
70 Torr
Remark
Naked lamp
Ne+Ar(95:5)
3. Primary Characteristics.
3.1. Requests of Specifications
Item
No.
Name
Code
Unit
Specification
Remark
1
Lamp Voltage
(Reference)
VL
Vrms
300 +/- 10%
IL
MArms
5.0 +/- 0.2mA
KD12300
inverter
12V
Vs
Vrms
450 +/- 10%
KD12300
6mA 25°C
B
Cd/m2
21000 +/- 10%
KD12300
6mA 25°C
2
3
4
5
Lamp Current
Starting
Voltage
(Reference)
Surface
Brightness
Color
Coordinates
6
Peak Spectrum
(Reference)
7
Stable Time of
Illumination
Plazmo Industries
x
y
Nm
Ts
min
0.286 +/- 0.010
0.283 +/- 0.010
Red
611
Green
544
Blue
440
CIE 1931
3min
2
3.2. Test Conditions
3.2.1. Lamp should be placed in horizontal position, under required testing current,
and undergo normal lighting for more than 3 minutes, then conduct the electrical
and optical properties tests
3.2.2. Temperature of Test Environment = 25°C±2°C
3.2.3. Relative Humidity of Test Environment = 65%±20%, under no wind state.
3.3. Test Apparatus
Test Items
Lamp Voltage
Lamp Current
Surface Brightness
Color and Color Temp Coordinates
Test Apparatus
Oscilloscope (Tektronix TDS1012B 100:1)
Multimeter (Fluke 8086 A)
Colorimeter (Topcon BM-7)
3.4. Test Methods
3.4.1. CCFL unit under complete voltage control; the test circuit as shown in the
Diagram below.
3.4.1.1. LV output end connected to negative of 0V ~ 12V input
3.4.1.2. The connection wire length is 100~300mm
3.4.1.3. Test circuit wires parallel distance should be longer than 100mm in order
to avoid possible interference which could affect measurement accuracy
3.4.1.4. When testing current disconnect VL test equipment
3.4.1.5. When testing voltage disconnect IL test equipment
3.4.1.6. During testing, place CCFL unit on shelf with black background in a nonreflective environment
Plazmo Industries
3
3.4.2. Brightness Measurement (naked lamp only), the Colorimeter should be kept a
distance of 500 +/- 10mm from the lamp vertical axis and test black perspective at
0.1 degrees.
3.4.3. NOTE: testing done with difference test equipment and under different test
conditions may result in measurement differences.
4. Drawing
Plazmo Industries
4
很抱歉,暂时无法提供与“CC26125”相匹配的价格&库存,您可以联系我们找货
