Narrow Beam LED Collimator Lens - Part No. 120
Designed for High Power Lambertian LED sources
High light collection efficiency of >85%
Precision moulded in optical grade Polycarbonate
for thermal stability and system durability
Part of the Polymer Optics “Modular LED Optics” ®
range
Polymer Optics “Modular LED Optics”® design,
based on a hexagonal format, allows maximum
packing density and assembly flexibility
POL optics are supplied pre-assembled into the appropriate holder to suit your chosen LED
package and are ordered by part number 120/xxx, where xxx is the required holder part number.
Typical Cartesian/Polar Output Intensity Plot
with 1mm die size high Power LED
Typical peak illuminance with a 1mm die size Lambertian high power LED = 16cd/lumen
In order to determine if the particular beam properties and performance of this optic are
suitable for your application with your chosen LED type, POL suggests that you obtain
samples from POL or their distributors for your own product testing, as properties may vary
with different LED types.
Performance values given are typical values and will vary dependent on LED type, binning, colour and drive profile.
Due to continuous product improvement, POL reserve the right to change specifications without notice.
© Copyright Polymer Optics Limited 2016
The details of the holder design will vary for each LED
type to provide the correct location to the LED package
and mounting height
Typical dimensional tolerances to
+/-0.2mm
Mounting Heights in Holder:
121 - 13.7mm
127 - 12.3mm
128 - 12.3mm
147 - 12.3mm
151 - 13.7mm
155 - 13.7mm
175 - 11.4mm
180 - 11.4mm
182 - 11.4mm
223 - 11.4mm
239 - 13.7mm
Lens Holder - Part No. 180
Designed to fit Luxeon Rebel LED packages or similar
devices
Simply mounts onto PCB over the LED and self-aligns to
the LED package
Precision moulded in high quality Polycarbonate for
Part of the Polymer Optics “Modular LED Optics”® range
Polymer Optics “Modular LED Optics”® design, based
on a hexagonal format, allows maximum packing density
POL optics are supplied pre-assembled into the appropriate holder to suit your chosen LED package
and are ordered by part number xxx/180, where xxx is the required optic part number.
Please see POL’s on-line product catalogue to determine the correct holder and optic combination for
your particular LED type
+/-0.2mm
The POL optics assembly can be attached to
the PCB with a range of adhesives including
epoxies, silicone based flexible adhesives,
special super-glues, etc. The final choice of
the adhesive will depend on the product
application working environment. However,
for most applications, POL recommends
using Loctite 460 which is a cyno-acrylate
“super glue” type adhesive, but a specially
formulated low odour, low bloom adhesive
for clear plastics. This adhesive will not
produce the white cloudiness which occurs
with other “super-glue” types and forms a
strong bond in seconds between the optics
holder and the PCB. Further information on
this, and other adhesives, can be found at
www.loctite.co.uk
很抱歉,暂时无法提供与“120/180”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 26+17.89619
- 50+17.51609
- 国内价格
- 2+18.30233
- 26+17.89619
- 50+17.51609
- 国内价格
- 100+20.59442
- 200+20.07893
- 400+19.77068
