Narrow Beam 7 Cell Cluster Optic - Part No. 261
Designed for low profile, high power, Lambertian LEDs
High light collection efficiency of >85%
Precision moulded in optical grade Polycarbonate for thermal
stability and system durability
Part of the Polymer Optics “Modular LED Optics”® range
Polymer Optics “Modular LED Optics”® design,
based on a hexagonal format, allows maximum
packing density and assembly flexibility
Typical dimensional tolerances
to +/-0.2mm
Polymer Optics “Cluster Optic”® arrays can be
assembled together in a number of ways to meet
the needs of a range of illumination applications
The 261, 262 and 264 type “Cluster Optics”® can
be mixed in the assembly to optimise the systems
illumination distribution, and combined with other
Polymer Optics custom cluster designs.
In order to determine if the particular beam properties and performance of this optic are suitable for
your application with your chosen LED type, POL suggests that you obtain samples from POL or their
distributors for your own product testing, as properties may vary with different LED types.
Due to continuous product improvement, POL reserve the right to change specifications without notice.
© Copyright Polymer Optics Limited 2016
Angular Beam Intensity Distribution
1.2
Relative Intensity
1
0.8
0.6
0.4
0.2
10
5
10
15
Off-axis Angle (Degrees)
Typical peak illuminace with 7x100 lumen Lambertian, 1mm die size LEDs = 14cd/lumen
很抱歉,暂时无法提供与“261”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+93.07892
- 50+91.06905
- 国内价格
- 1+94.52645
- 25+93.07892
- 50+91.06905
- 国内价格
- 100+106.98245
- 200+104.30817
- 400+102.70340
