533-N
533-N
    POLYMEROPTICS(聚合物光学)
    HIGH BAY - NATURAL
533-N 数据手册
HIGH BAY LENS FOR PIR MOTION SENSING OVERVIEW Ceiling mounted lens for high bay areas such as warehouses, distribution centres, factories and atriums. Designed to function with a single pyro but can be configured with three pyro’s for additional sensitivity. FEATURES Array of 43 Individual Fresnel Facets Up to 172 detection zones with a single qual pyro Up to 516 detection zones with a three pyro arrangement Aspheric Fresnels for better optical performance Designed using optical ray-tracing software Other flange shapes can be cropped from rectangle Available in natural and white colours Part Number 533C 533W Drawing A3-10533 A3-10533 Colour Natural White APPLICATIONS PIR detection for warehouses, shops, offices and workshops Lighting and air conditioning control Alarms and security 64 +0.05 X X 26 32 Theoretical zone plot. Optimum range is 12m. Maximum Range 14m depending on electronic gain 11.0 52 24.0 11.0 3.00 Diagram shows theoretical zone plot for detector mounted 14m above floor. Mounting height can be reduced as required. The lens has a 1:1 aspect ratio, therefore when mounted at 12m height, the lens projects 43 zones into a 24m diameter floorspace. 11.0 36.0 11.0 14.0 PYRO ELEMENT POSITION (TYP. PYRO LHi1128 QUAD) R30 11.5 0.5 26.0 (REF.) 17.0 c 2019 Polymer Optics Limited ALL DIMENSIONS IN mm SECTION 45.0 X-X Zone plot using optical ray-tracing software Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: +44 (0)2476 937394 www.polymer-optics.co.uk HIGH BAY LENS FOR PIR MOTION SENSING HIGH BAY LENS PIR lens for motion detection. For use in security or lighting control applications where there are relatively high ceilings. 3 PYRO MODE To improve the density of the zone pattern, and hence to increase detection sensitivity, the High Bay lens can also be used in a 3 pyro configuration. We recommend tilting the pyro’s according to the pictures below. A pyro holder design is available to download from the POL website. It can be used to 3D print a prototype holder, or it can be used under licence to manufacture a plastic mould tool. APPLICATIONS Warehouses and factories Atriums Leisure centres, gyms, sports halls Street Lights, Car Parks Diagram shows theoretical zone plot for detector mounted 14m above floor. Mounting height can be reduced as required. When used with a quad pyro the lens will project 516 individual detection zones within a 40m diameter circular area. c 2019 Polymer Optics Limited ALL DIMENSIONS IN mm Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: +44 (0)2476 937394 www.polymer-optics.co.uk
533-N 价格&库存
很抱歉,暂时无法提供与“533-N”相匹配的价格&库存,您可以联系我们找货
