FLAT CAP LENS
CEILING 360
FOR PIR MOTION SENSING
OVERVIEW
Motion detection lens for security and
lighting applications. 360deg beam pattern
with 100deg FOV within 6m diameter area.
Lens can be flush mounted with product
housing - ideal for devices where strong
aesthetic appearance is important.
FEATURES
Flat Cap Lens 360
Designed to press onto standard T05 pyro
Fresnel lenses fo maximise IR collection
Uses POL’s unique free-form Fresnel system
Designed using optical ray-tracing software
Compact shape with clearance for pcb components
Available in natural, white and black colours
Part Number
713-N
713-W
713-B
Drawing
A3-10713
A3-10713
A3-10713
Colour
Natural
White
Black
Note: White material has 25% lower IR transmission than natural material.
Black material has 35% lower IR transmission than natural material.
Typical mounting method: 20x1mm o-ring stretched around
lens flange. PCB screwed to housing via pillars. Orientation
tab sits in channel next to fixing pillar.
TYPICAL PYRO EXCELITAS PYQ 1348
QUAD ELEMENT PYRO. IF POSSIBLE,
CHOOSE SMALL ELEMENT VERSION
(DIMENSIONS ARE BASED ON THIS
CHOICE OF PYRO)
c
2017 Polymer Optics Limited
ALL DIMENSIONS IN mm
Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England
Tel: 02476 937394
www.polymer-optics.co.uk
FEATURES
Horizontal curtain and circular beam patterns
Choice of profile shape to suit product styling
Dome Cap Lens HC
Dome Cap Lens 360
Flat Cap Lens HC
Flat Cap Lens 360
APPLICATIONS
Office and household lighting control
Motion detection for security applications
Individual luminaire switching
Fan and air conditioning control
Control panel illumination for appliances
Vending machines, ATM’s, streetlights
Lens pushes onto TO5 pyro. Slot in flange ensures correct
orientation with pyro. Casing traps lens flange so that lens
is held securely. ‘O’ ring can be used to seal. Lens has
clearance for PCB components. Sealed lens environment
prevents false detections from contamination and air
movement. Indicator LED can project light through lens.
Low voltage sensor modules
are available. Sensor
modules have analogue pyro
with switching circuit and
sensitivity sdjustment. Can
be combined with relay
module for mains switching.
Modules can be used for
alarm activation or lighting.
Cap lenses can be ordered to
fit most of the leading
pyro-electric sensor brands
such as Excelitas, Nicera,
Murata and Panasonic. The
lens presses onto the T05
cannister and is held at the
correct focal distance.
Small and compact, these lenses are
suitable for numerous security and lighting
applications, in the office, or around the
home. Available in two beam pattern
versions, horizontal curtain (HC) and
360deg ceiling, there is a lens suitable for
every application.
Tel: 02476 937394
很抱歉,暂时无法提供与“713-W”相匹配的价格&库存,您可以联系我们找货
