This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2021, PUI Audio Inc.
Data Sheet
PRELIMINARY AS02508CO-4-R
Specifications
Parameters
Rated Input Power
Max Input Power
Impedance
Output SPL 1.0W/10cm (AVG
0.8, 1.0, 1.2, 1.5 kHz)
Resonant Frequency
Frequency Range
THD (2kHz, 1.0W)
Frame Material
Magnet Material
Diaphragm Material
Weight
Buzz, Rattle, etc.
Environmental Compliances
Polarity
Storage Temperature
Operating Temperature
Values
1.0
1.5
8 ± 20%
Units
Watts
Watts
Ohms
95 ± 3
dB
1100 ± 20%
Fo ~ 20,000
5% max
ABS
NdFeB
Cloth
2.5
Should not be audible at 2.83Vrms sine wave
between (200 Hz ~ 5KHz)
ROHS/REACH
When a positive DC Current is applied to the
voice coil terminal marked + or red, the
diaphragm shall move forward
-40 ~ +80
-40 ~ +80
Hz
Hz
Grams
Measurement Method (Temperature: 23 ~ 25°C; Humidity: 55%; Power: 0.1W)
www.puiaudio.com
°C
°C
Typical Frequency Response (2.83Vrms, 10cm)
Reliability Testing
Type of Test
High Temperature Test
Low Temperature Test
Humidity Test
Test Specifications
96 hours at 80 ± 3°C and let rest at room
temperature for 3 hours
96 hours at -40 ± 3°C and let rest at room
96 hours at 40 ± 3°C with relative humidity at 90
~ 95% and let rest at room temperature for 3
hours
Low temperature: -40℃±3℃, temperature:
Temperature Cycle Testing
+80℃ ± 3℃, 1 cycle: total 5 cycles and then keep
6 hours in room temperature
Frequency:10~55~10Hz Oct/mm
Amplitude:1.5mm
Vibration Test
X, Y, Z 3 direction.2 hours each, total 6 hours
Free drop one piece 100cm height to a 20mm
thick board in x,y,z direction for one time each,
total six times.
Drop Test
Load Test
Rated Power white noise is applied for 96 hours
After each test the change of SPL shall be within ±3 dB.
www.puiaudio.com
Dimensions
Packaging
www.puiaudio.com
Revision
A
Note:
1.
2.
Specifications Revisions
Description
Released from Engineering
Unless otherwise specified:
A. All dimensions are in millimeters.
B. Default tolerances are ±0.5mm and angles are ±3°.
Specifications subject to change or withdrawal without notice.
www.puiaudio.com
Date
11/18/2021
很抱歉,暂时无法提供与“AS02508CO-4-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+41.363941+5.13118
- 10+34.1159210+4.23207
- 25+31.4565125+3.90217
- 72+29.5240472+3.66245
- 144+27.66550144+3.43190
- 288+26.00542288+3.22596
- 504+24.49773504+3.03894
