1093
    ADAFRUIT
    PULSE SENSOR AMPED
1093 数据手册
WORLD FAMOUS ELECTRONICS llc. www.pulsesensor.com PULSE SENSOR EASY TO USE HEART RATE SENSOR & KIT General Description The Pulse Sensor is the original low-cost optical heart rate sensor (PPG) for Arduino and other microcontrollers. It’s designed and made by World Famous Electronics, who actively maintain extensive example projects and code at: www.pulsesensor.com Absolute Maximum Ratings Operating Temperature Range Input Voltage Range Output Voltage Range Supply Current Features ● ● ● ● ● ● Includes Kit accessories for high-quality sensor readings Designed for Plug and Play Small size and embeddable into wearables Works with any MCU with an ADC Works with 3 Volts or 5 Volts Well-documented Arduino library Min Max Unit -40 +85 °C 3 5.5 V Vdd V 4 mA 0.3 3 Typ Vdd/2 Pulse Sensor Kit Contents “PulseSensor.com” is a registered trademarks of World Famous Electronics LLC. NY, USA 1/2 Physical Dimensions PCB inch(mm) Cable Specs ● Length 610 mm (24 inches) ● 26 Gauge ● PVC Insulation, Ribbon Style ● Male Header Termination ○ Black Wire = GND ○ Red Wire = Vdd ○ Purple Wire = Pulse Signal “PulseSensor.com” is a registered trademarks of World Famous Electronics LLC. NY, USA 2/2
很抱歉,暂时无法提供与“1093”相匹配的价格&库存,您可以联系我们找货
