UNIVERSAL IP67 CASE
UNIVERSAL IP67 CASE
    PYCOM
    IP67 CASE FOR PYSENSE/PYTRACK AN
UNIVERSAL IP67 CASE 数据手册
            Universal IP67 Case  IMPORTANT UPDATE:The Universal IP67 Case will be in stock early February 2019.    No drills, all thrills.    The Universal IP67 Case is Pycom’s very own universal waterproof case, with push‐in tabs that fit  accessory sensors perfectly, creating a water tight seal. Two holes go straight through the case  without penetrating the inner compartment, meaning you can fix the case securely in place.  The case features perfectly sized spacing for a Pycom expansion board or sensor shield, a Pycom  module and battery, plus sensors.    Description  *****     The Universal IP67 Case will be shipping from 02 February 2019     *****    No drills, all thrills.    The Universal IP67 Case is Pycom’s very own universal waterproof case, with push‐in tabs that fit  accessory sensors perfectly, creating a water tight seal. Two holes go straight through the case  without penetrating the inner compartment, meaning you can fix the case securely in place.  The case features perfectly sized spacing for a Pycom expansion board or sensor shield, a Pycom  module and battery, plus sensors.    The outer dimensions of the case are: 8.8 x 8.8 x 4cm  The Universal IP67 Case has push‐in tabs that specifically fit the following sensors perfectly (coming  soon), as well as all of our antennas, which you can purchase separately:     2MP Camera   Infrared Image Sensor   Barcode Reader   Fingerprint Scanner   OLED Screen (11mm x 12mm screen area)    Additional information  Weight  0.1 kg  Black  Black, Transparent        https://pycom.io/product/universal‐ip67‐case/3‐12‐19
UNIVERSAL IP67 CASE 价格&库存
很抱歉,暂时无法提供与“UNIVERSAL IP67 CASE”相匹配的价格&库存,您可以联系我们找货
