QLSP01WCF
QLSP01WCF
    QUELIGHTING
    LED 照明 - 白色,冷色 6000K 3.1V 60mA 120° 1206(3014 公制)
QLSP01WCF 数据手册
QLSP01WCF ( Sideview 3014) QLSP01WCF V1.1 Product Outline: These high output reflector type Tube LEDs are available in warm white /neutral white / pure white / and cold white to suit customer’s application. This LEDs can be use as a side emitter for directional lighting needs. With special binning technology, these LEDs are ideal for architecture lighting and special lighting needs. Features: • • • • • • • High brightness output @ 60mA Package Dimension = 3.0mmX1.4mmX1.2mm CRI = 80 and above Available in warm white / neutral white / pure white / and cold white RoHS compliant MSL 3 Custom Bin available upon special request Application: • • • • Architecture Lighting Garden Lighting Interior Lighting Special application lighting Compliance and Certification: 1 QLSP01WCF V1.1 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP01WCF V1.1 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 60 mA Power Dissipation Pd 0.2 W Pulse Forward Current Ifp 90 mA LED Junction Temperature TJ 120 ℃ Storage Temperature Tstg -40 ~ 80 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Tsol 260 < 5 sec ℃ (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: t < 100 μs;D = 0.001;Ta= 25 °C ◼ Electrical / Optical Characteristic Parameter Symbol Condition (Ta=25 oC) Min. Typ. 2.8 Max. Unit 3.4 V Forward Voltage Vf Color Rendering Index Ra View Angle θ 120 deg Thermal Resistance Rth 45 oC/W 60mA 80 (1) Tolerance of measurement: VF=+/- 0.1V (2) The CRI tolerance is ±2. (3) Thermal resistance is calculated from junction to solder 3 QLSP01WCF V1.1 ◼ Specification Chromaticity Coordinates CCT CCT CCT CCT 6000k 5000k 4000k 3000k 66AD-2 50K 40K 30K CIE X CIE Y CIE X CIE Y CIE X CIE Y CIE X CIE Y 0.3212 0.3295 0.3368 0.341 0.3681 0.3627 0.4295 0.3941 0.3289 0.3267 0.3374 0.3571 0.3725 0.3825 0.4381 0.412 0.3218 0.3171 0.3454 0.364 0.3845 0.39 0.4515 0.4168 0.3141 0.3204 0.3441 0.3468 0.3794 0.37 0.442 0.3985 0.3212 0.3295 0.3368 0.341 0.3681 0.3627 0.4295 0.3941 4 QLSP01WCF V1.1 Forward Voltage (VF) Bin: VF Rank @ 60mA Code name Min. Max. Units 01 23 45 2.8 3.0 3.2 3.0 3.2 3.4 V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Intensity Rank (mcd) @ 60mA Code name Min. Max. QI 18 20 QJ 20 22.5 QK 22.5 25 Units lm Luminous intensity tolerance is ± 7% 5 QLSP01WCF V1.1 ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 6 QLSP01WCF V1.1 (3). Forward Current vs Relative Luminous Intensity (4). Forward Current vs Forward Voltage 7 QLSP01WCF V1.1 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 60 mA △Vf< 10% Luminous Flux Iv 60 mA △Iv< 30% 8 QLSP01WCF V1.1 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 9 QLSP01WCF V1.1 ◼ Taping & Packing: Unit : mm 10 QLSP01WCF V1.1 ◼ Labeling ◼ Ordering Information: Part # QLSP01WCF Multiple Quantities Quantity per Reel 3000 pcs 11 QLSP01WCF V1.1 ◼ Revision History: Revision Date: Changes: Version #: 1-29-2016 Initial release 1.0 08-26-2019 Update the led performance, operation current and CIE binning 1.1 12
QLSP01WCF 价格&库存
很抱歉,暂时无法提供与“QLSP01WCF”相匹配的价格&库存,您可以联系我们找货
