QLSP04PCAU
QLSP04PCAU
    QUELIGHTING
    LED 照明 - 彩色 - 琥珀色 592nm(588nm ~ 595nm) 1212(3030 公制)
QLSP04PCAU 数据手册
QLSP04PCAU (3030 PC Amber) QLSP04PCAU V2.0 Product Outline: This is the high power LED with reflector type. EMC 3030 Single color is a surface-mount LED which with heat sink to enhance operating performance. With special binning technology, these LEDs are ideal for architecture lighting and special lighting needs. Features: • • • • • • • PC Amber color LED High brightness output @ 350mA, High driving current to 500mA. Package Dimension = 3.2mmX3.0mmX0.6mm RoHS compliant Custom Bin available upon special request View angel >110° Application: • • • • Warning lamp Decoration lamp Architecture Lighting Garden Lighting Compliance and Certification: 1 QLSP04PCAU V2.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP04PCAU V2.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 500 mA Leakage Current Ir 1.0 μA Power Dissipation Pd 1.7 W Pulse Forward Current Ifp 700 mA LED Junction Temperature TJ 125 ℃ Storage Temperature Tstg -40 ~ 100 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition Forward Voltage Vf View Angle θ ESD Sensitivity(HBM) KV Thermal Resistance Rth (Ta=25 oC) Min. Typ. 3.0 Max. Unit 3.5 V 120 350mA deg 8.0 ℃/W 10 (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product QLSP04PCAU Color PC Amber Vf(V) Dominant IF=350mA Wavelength(nm) 3.2 588~595 Luminous Flux IF=350mA Min. Typ. 110 118 *Tolerance = +/- 10% 3 QLSP04PCAU V2.0 ◼ Groups CIE bin table 4 QLSP04PCAU V2.0 Forward Voltage (VF) Bin: VF Rank @ 350mA Code name Min. Max. 2 3 3.1 3 3.1 3.2 4 3.2 3.3 5 3.3 3.4 Units V The forward voltage tolerance is ± 0.1V Luminous Flux Bin: lm Rank (lm) @ 350mA Code name Min. Max. QPE 110 118 QPF 118 126 Units lm Luminous flux tolerance is ± 7% 5 QLSP04PCAU V2.0 ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 6 QLSP04PCAU V2.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 7 QLSP04PCAU V2.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 350 mA △Vf< 10% Luminous Flux Iv 350 mA △Iv< 30% 8 QLSP04PCAU V2.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 9 QLSP04PCAU V2.0 ◼ Taping & Packing: Unit : mm 10 QLSP04PCAU V2.0 11 QLSP04PCAU V2.0 ◼ Labeling ◼ Ordering Information: Part # QLSP04PCAU-XXX Multiple Quantities Quantity per Reel 1000,2000 pcs 12 QLSP04PCAU V2.0 ◼ Revision History: Revision Date: Changes: Version #: 09-02-2015 Initial release 1.0 09-15-2016 Update the performance 1.1 08-01-2018 Update the performance 1.2 09-22-2020 Upgrade the performance 2.0 13
QLSP04PCAU 价格&库存
很抱歉,暂时无法提供与“QLSP04PCAU”相匹配的价格&库存,您可以联系我们找货
