PART NUMBER :R284C0351024
TECHNICAL DATA SHEET
CABLE ASSEMBLY
Cable Assembly Business Unit
No.390, Yong He Road,
Shanghai 200072, China
Customer :
Specification : xxxx
Issue : NA
Date : NA
Issue : xxx
Date : xxx
All dimensions are in mm
500 +/-10 mm
237 +/- 5mm
2X R280.570.000
Radiall
Radiall
R284C0351024
RADIALL ww/yy
R161.083.000
501.14.033A
Connectors designation :
Connector 1 : BNC Straight Plug Crimp Type for
Cable 5/50D (R141.083.000)
Cable designation :
Flexible Cable 5/50D (RG142)
C291.320.007
Lg: 500mm
Nominal length :
Cable colour :
R141.083.000
RG142
C291.320.007
Connector 2 : N Straight Plug Full-Crimp Type for
Cable 5/50D (R161.083.000)
Brown
4.95mm
Outer diameter :
ELECTRICAL CHARACTERISTICS :
High Frequency
Low Frequency
Characteristic impedance : 50±2 Ohms
Insulation Resistance : 5000 MOhms min
Frequency range : DC-4GHz
Voltage Rating : 500 Veff max
Insertion Loss max : 0.56dB max at 3GHz and 20℃
VSWR. : TBT
MECANICAL CHARACTERISTICS :
Recommend. Min. bending radius : 25 mm
Cable crush resistance : NA
Life ( connectors) : 500 cycles
ENVIRONMENTAL CHARACTERISTICS :
Operating temperature range :
-55℃ to +155℃
Remark : NA
CUSTOMER'S APPROVAL
Service or
Company's stamp
Attachment : R141.083.000-TDS
Name
Date
R161.083.000-TDS
C291.320.007(RG142)-TDS
Cable Assembly is RoHS compliant.
Jack Lv
Name
A
Issue
2007-06-08
Date
Creation
Garet Xie
Modification
Checked by
PART NUMBER :R284C0351025
CABLE ASSEMBLY
Customer :
Issue : NA
Date : NA
Issue : xxx
Date : xxx
1000 +/-20 mm
487 +/- 10mm
2X R280.570.000
Radiall
Radiall
R284C0351025
RADIALL ww/yy
R161.083.000
501.14.033A
Cable designation :
C291.320.007
Lg: 1m
Nominal length :
Cable colour :
R141.083.000
RG142
C291.320.007
Brown
4.95mm
Outer diameter :
High Frequency
Low Frequency
Insertion Loss max : 1.01dB max at 3GHz and 20℃
VSWR. : TBT
-55℃ to +155℃
Remark : NA
CUSTOMER'S APPROVAL
Service or
Company's stamp
Name
Date
R161.083.000-TDS
Jack Lv
Name
A
Issue
2007-06-08
Date
Creation
Garet Xie
Modification
Checked by
很抱歉,暂时无法提供与“R284C0351025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+900.09918
- 15+873.08569
- 50+846.06178
- 100+828.06667
- 250+810.05073
