IoT LoRa Node pHAT for Raspberry Pi
(868MHz/915MHz)
LoRa (Long Range) is the smart, long‐range, wireless transmission technology that
is enabling the future of IoT (Internet of Things).
Our IoT LoRa Node pHAT allows you to create an inexpensive LoRa node,
compatible with The Things Network, in conjunction with a Raspberry Pi or other
single board computers. This pHAT allows quicker prototyping as it has the LoRa
stack on the chip. Add sensors, buttons and more to complete your LoRa network!
The IoT LoRa Node pHAT uses the RAKWireless RAK811 LoRa node modulewhich is
based on Semtech SX1276 LoRa technology.
The board can be configured to use either of the two different frequencies listed
below:
868 MHz
915 MHz
Need more information about frequencies in your region? Click here.
Features
Uses RAK811 LoRa Radio with full LoRaWAN Stack embedded
Communicates with the Raspberry Pi over UART only using a total of 3 GPIO Pins for
the module.
Supports LoRaWAN Connections and LoRaP2P Modes.
u.FL connector and antenna allowing different antennas to be used or integrated
into boxes with external antennas.
Low power ‐ uses less than 50mA During transmission
Pair the LoRa Node pHAT with our LoRa Gateway HAT
We also have a LoRa Gateway HAT designed for the Raspberry Pi that works with all
of the LoRa nodes we sell.
IoT LoRa Gateway HAT for Raspberry Pi
Compatible with
Raspberry Pi A+
Raspberry Pi B+
Raspberry Pi 2B
Raspberry Pi 3B
Raspberry Pi 3B+
Raspberry Pi Zero
Raspberry Pi Zero W
Plus any other Raspberry Pi with 40 GPIO Pins
What's Inside?
IoT LoRa Node pHAT
RAK811 Pre‐assembled
Mounting Hardware
Stickers
Info card
Setup Guides
GitHub
https://uk.pi‐supply.com/products/iot‐lora‐node‐phat‐for‐raspberry‐pi/5‐7‐19
很抱歉,暂时无法提供与“PIS-1128”相匹配的价格&库存,您可以联系我们找货
