SC0480
SC0480
    RASPBERRYPI(树莓派)
    2.45GHz,5.45GHz 鞭状,倾斜 RF 天线 2.4GHz ~ 2.5GHz,5.1GHz ~ 5.8GHz 2dBi SMA 母头 螺钉
SC0480 数据手册
Raspberry Pi Compute Module 4 Antenna Kit Published in October 2020 by Raspberry Pi Trading Ltd. www.raspberrypi.org Overview This Antenna Kit is certified for use with Raspberry Pi Compute Module 4. If a different antenna is used, then separate certification will be required, and this must be arranged by the end-product design engineer. Specification: antenna Model number: YH2400-5800-SMA-108 Frequency range: 2400-2500/5100-5800 MHz Bandwidth: 100–700MHz VSWR: ≤ 2.0 Gain: 2 dBi Impedance: 50 ohm Polarisation: Vertical Radiation: Omnidirectional 2 Maximum power: 10W Connector: SMA (female) Raspberry Pi Compute Module 4 Antenna Kit Dimensions: 108 mm × 10 mm Shell material: ABS Installation: Screw Operating temperature: -35 to +75°C Weight: ± 3 g Specification – SMA to U.FL cable Model number: HD0052-09-A01_A0897-1101 Frequency range: 0–6GHz Impedance: 50 ohm VSWR: ≤ 1.4 Maximum power: 10W Connector (to antenna): SMA (male) Connector (to CM4): U.FL Dimensions: 205 mm × 1.37 mm (cable diameter) Shell material: ABS Operating temperature: -45 to +80°C Compliance: For a full list of local and regional product approvals, please visit w ww.raspberrypi.org/documentation/hardware/ raspberrypi/conformity.md 3 Raspberry Pi Compute Module 4 Antenna Kit Physical dimensions 8 87.5 ± 1 10 205 ± 1 1/4–36UNS–2A 1/4–36UNS–2B S=8 6.25 Milling unilateral 5.85 ± 0.02 4 Raspberry Pi Compute Module 4 Antenna Kit 11 2.0 Fitting instructions 1 Connect the U.FL connector on the cable to the U.FL-compatible connector on Compute Module 4 2 Screw the toothed washer onto the SMA (male) connector on the cable, then insert this SMA connector through a hole (e.g. 6.4 mm) in the end-product mounting panel 3 Screw the SMA connector into place with the retaining hexagonal nut and washer 4 Screw the SMA (female) connector on the antenna onto the SMA (male) connector which now protrudes through the mounting panel 5 Adjust the antenna to its final position by turning it through up to 90°, as shown in the illustration below 5 3 4 2 1 WARNINGS • This product shall only be connected to a Raspberry Pi Compute Module 4. • All peripherals used with this product should comply with relevant standards for the country of use and be marked accordingly to ensure that safety and performance requirements are met. These articles include but are not limited to keyboards, monitors and mice when used in conjunction with the Raspberry Pi. SAFETY INSTRUCTIONS To avoid malfunction or damage to this product, please observe the following: • Do not expose to water or moisture, or place on a conductive surface whilst in operation. • Do not expose it to external heat from any source. The Raspberry Pi Compute Module 4 Antenna Kit is designed for reliable operation at normal ambient room temperatures. • Take care whilst handling to avoid mechanical or electrical damage to the Compute Module 4, Antenna, and connectors. • Avoid handling the unit whilst it is powered. 5 Raspberry Pi Compute Module 4 Antenna Kit 6 Raspberry Pi Compute Module 4 Antenna Kit Raspberry Pi and the Raspberry Pi logo are trademarks of the Raspberry Pi Foundation www.raspberrypi.org
SC0480 价格&库存
很抱歉,暂时无法提供与“SC0480”相匹配的价格&库存,您可以联系我们找货
