RAM-6700-VZ-MX
RAM-6700-VZ-MX
    REDLIONCONTROLS(美国红狮)
    CELLULAR RTU: I/O CONCENTRATOR A
RAM-6700-VZ-MX 数据手册
RAM® 6000 Cellular RTUs Sixnet Networking Series Cellular Automation Red Lion’s Sixnet series RAM 6000 industrial cellular RTUs with 4G LTE provide a rugged, reliable solution for monitoring and controlling remote assets and processes in extreme conditions. RAM 6000 RTUs seamlessly connect Modbus or DNP3 enabled SCADA equipment with master station or control center servers utilizing secure cellular 4G LTE or 3G wireless networks. A built-in I/O concentrator allows the RAM 6000 to collect local sensor data and optimize the cellular bandwidth by optionally reporting only on an exception. Ideal for deployment in industrial M2M networks such as oil and gas, water/wastewater, utility, transportation and mining applications, our industrial cellular RTUs provide a reliable network extension to remote locations. The end result helps customers save wiring time, space and cost by combining separate functions into one cellular device. APPLICATIONS PRODUCT HIGHLIGHTS >> Oil & Gas >> High-performance 4G LTE cellular connectivity >> Water/Wastewater >> Natively supports Modbus and DNP3 protoocols >> Utility >> Multiple communication ports >> Transportation >> Routing capabilities provide secure, reliable communication >> Mining FEATURES & BENEFITS >> Out-Of Band Management (OOBM) >> Multiple Communication Ports • Secure remote CLI access via RS232 port • One RS232 serial port, and up to five Ethernet ports provide seamless connectivity to remote devices • Pre-loaded with many console port configurations >> Rugged, High-Performance Design >> Secure Ethernet Connectivity • Reliable operation in rugged environments • Routing capabilities for reliable communication • -40° to 75°C operating temperature* • Stateful firewall, SSL, GRE and VPN services and packet inspection reduce the risk of unwanted access >> Modbus and DNP3 Support >> Easy Configuration Options • Easily communicates with SCADA equipment with native protocols • Streamlined web-browser interface C UL R LISTED US compliant RAM 6000 Specifications WIRELESS INTERFACE AT&T LTE with fall back to HSPA+ Bell Mobility LTE with fall back to HSPA+ Generic LTE with fall back to HSPA+ Manitoba LTE with fall back to HSPA+ Rogers LTE with fall back to HSPA+ Sprint EVDO Rev. A with fall back to 1xRTT TELUS LTE with fall back to HSPA+ Verizon LTE with fall back to EVDO Dual-band CDMA2000 EVDO Rev. A (backward compatible with 1xRTT) GSM/HSPA+ (backward compatible with EDGE) PROGRAMMABLE PLATFORM Software Development Kit (SDK) C/C++/Perl PROTOCOL GATEWAY I/O controller Modbus RTU/TCP/ASCII DNP3 – slave SYSTEM PERFORMANCE 32-bit ARM9 400 MHz CPU 512 MB NAND 128 MB RAM TUNNELING IPsec, GRE, OpenVPN IP NAT, port forwarding, dynamic DNS, DHCP Stateful inspection firewall, IP transparency ETHERNET INTERFACE (10/100 AUTO-SENSING) 1x or 5x RJ45 WAN capability on 5th port SERIAL INTERFACE 1x RS232 serial DB9 115200bps USB INTERFACE 1x USB 2.0 device mini INPUTS & OUTPUTS 1x digital/analog inputs 1x digital output (open-collector) DIMENSIONS in inches (mm) POWER INPUT Range: 8-30 VDC (12 or 24 VDC nominal) Standby: 1.4W - 3.3W (typical) Transmitting: 6401: 2.0W – 5.0W 6421: 3.4W – 6.4W 660x: 2.0W – 2.9W 6621: 3.6W – 4.5W 680x: 2.6W – 5.0W 6821: 4.2W – 6.6W 670x: 2.6W – 6.9W 6721: 4.3W – 8.7W Heat dissipation: 30 BTU/hour max MECHANICAL RAM-6x0x Dimensions: 120 x 96 x 32 mm (4.7” x 3.77” x 1.25”) Weight: 453g (1 lb) RAM-6x21 Dimensions:120 x 96 x 51 mm (4.7” x 3.77” x 2.0”) Weight: 500g (1.1 lbs) ENVIRONMENTAL Operating temperature: -40° to +75°C* Shock: IEC60068-2-27 Vibration: IEC60068-2-6 Humidity: 5 to 95% non-condensing CERTIFICATION EMI/EMC: Emissions: FCC, Part 15 and Industry Canada, ICES-003; Class A; EN55022, IEC61000-6-4 Immunity: IEC61000-6-2 (EN61000-4-2,3,4,5,6,8) Hazardous locations: Class I, Div. 2, Groups A, B, C, D, ISA 12.12.01 Electrical safety: UL508/CSA22.2/14 (CUL); IEC61010-1 Carrier specific approvals RoHS compliant WARRANTY 3 years on design and manufacturing defects * See Hardware Manual for thermal considerations. RAM 6000 Specifications ORDER GUIDE PART NUMBER PRODUCT LINE SERIAL RS232 ETHERNET 10/100 CELLULAR RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM RAM 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 5 5 1 1 1 1 1 1 5 5 1 1 1 1 1 1 5 5 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 4G LTE 4G LTE 4G LTE 4G LTE 4G LTE 4G LTE 4G LTE 4G LTE 3G/GSM 3G/GSM 3G/GSM 3G/GSM 3G/GSM 3G/GSM 3G/GSM 3G/GSM RAM-6600-(Carrier Code) RAM-6600-(Carrier Code)-AC RAM-6600-(Carrier Code)-MX RAM-6601-(Carrier Code) RAM-6601-(Carrier Code)-AC RAM-6601EB-(Carrier Code) RAM-6621-(Carrier Code) RAM-6621-(Carrier Code)-AC RAM-6700-(Carrier Code) RAM-6700-(Carrier Code)-AC RAM-6700-(Carrier Code)-MX RAM-6701-(Carrier Code) RAM-6701-(Carrier Code) RAM-6701EB-(Carrier Code) RAM-6721-(Carrier Code) RAM-6721-(Carrier Code)-AC RAM-6800-(Carrier Code) RAM-6800-(Carrier Code)-AC RAM-6800-(Carrier Code)-MX RAM-6801-(Carrier Code) RAM-6801-(Carrier Code)-AC RAM-6801EB-(Carrier Code) RAM-6821-(Carrier Code) RAM-6821-(Carrier Code)-AC POWER CONNECTOR Molex end connector cable AC adapter AC adapter/Molex end connector DC powered AC adapter PoE (Power Over Ethernet) DC powered AC adapter Molex end connector cable AC adapter AC adapter/Molex end connector DC powered AC adapter PoE (Power Over Ethernet) DC powered AC adapter Molex end connector cable AC adapter AC adapter/Molex end connector DC powered AC adapter PoE (Power Over Ethernet) DC powered AC adapter * See Band/Frequency table for compatability FREQUENCY SPECIFICATIONS PART NUMBER RAM-66XX-SP/VZ RAM-67XX-AT/BM/GE/MTS/RO/TE RAM-67XX-VZ RAM-68XX-AT/BM/GE/MTS/RO/TE Connect. Monitor. Control. PRODUCT LINE EVDO: 800/1900 MHz CDMA: 800/1900 MHz LTE: Bands 1, 4, 17; Frequencies 700/2100MHz, AWS (1700/2100) MHz HSPA: Bands 1, 2, 5, 6; Frequencies 800/850/1900/2100 MHz GSM: 850/900MHz LTE: Band 13; Frequency 700 MHz WCDMA: 850/900/1900/2100 MHz HSPA: Bands 1, 2, 5, 6, 8; Frequencies 800/850/900/1900/2100 MHz GSM: 850/900/1800/1900 MHz SUPPORTED CARRIERS (SP) Sprint; (VZ) Verizon (AT) AT&T; (BM) Bell Mobility; (GE) Generic*; (MTS) Manitoba; (RO) Rogers; (TE) TELUS; (VZ) Verizon (AT) AT&T; (BM) Bell Mobility; (GE) Generic*; (MTS) Manitoba; (RO) Rogers; (TE) TELUS
RAM-6700-VZ-MX 价格&库存
很抱歉,暂时无法提供与“RAM-6700-VZ-MX”相匹配的价格&库存,您可以联系我们找货
