Consisting of two TRS connectors wrench-crimped to each end of a twinax cable, this is a top grade cable assembly that is perfect for many MIL-STD-1553B
systems. The TRS PL155-47 connectors and M17/176-00002 twinaxial cable lend to an assembly that withstands a wide temperature range, offers exceptional
shielding, and meets stringent military & organizational specifications. As such, this cable assembly is ideal for a variety of military & civil high frequency signal
transmission operations, including avionics, spacecraft, laboratory, medical, & general control system applications.
· Workmanship per IPC/WHMA-A-620, Class 3, Section 13
· Bend Radius: 0.75" minimum
· RoHS compliant
· 100% Tested for continuity and a dielectric withstanding voltage of 1000 VRMS
RCA-11-XXX
TRS/TRS MIL-STD-1553B
Twinax Cable Assembly
Data Sheet
Remington Industries
is proud to offer our
TRS/TRS TWINAX CABLE (RCA-11) DATA SHEET - REMINGTON INDUSTRIES
Custom Wire Services
Our exclusive inventory of
in-stock wire and ability to
procure wire of all kinds makes
us the perfect partner for wire
purchasing and custom wire
services. We are proud to
provide essential, high quality
wire for engineering projects,
educational science projects,
coil winding, and electronics
applications.
CABLE LENGTH
(SEE TABLE BELOW)
RCA-11-XXX
Some of our many wire services
include the following:
- Wire Re-Packaging
- Bifilar & Trifilar Windings
- Wire Processing
- Coil Winding
- Wire Procurement Services
LABEL (with Remington cable
assembly P/N, Cage code, & date code)
If you have any questions or
need any information about our
Wire Services, feel free to
contact us! It only takes one
call to get experienced
assistance.
M17/176-00002
CABLE
x2 TRS PL155-47
CONNECTORS
Contact us by phone:
(815) 385-1987
PART NUMBER
CABLE LENGTH *
1 ft (0.30 m)
RCA-11-12
2 ft (0.61 m)
RCA-11-24
3 ft (0.91 m)
RCA-11-36
4 ft (1.22 m)
RCA-11-48
5 ft (1.52 m)
RCA-11-60
6 ft (1.83 m)
RCA-11-72
8 ft (2.44 m)
RCA-11-96
10 ft (3.05 m)
RCA-11-120
12 ft (3.66 m)
RCA-11-144
15 ft (4.57 m)
RCA-11-180
20 ft (6.10 m)
RCA-11-240
25 ft (7.62 m)
RCA-11-300
50 ft (15.24 m)
RCA-11-600
* Tolerance per IPC/WHMA-A-620, Section 11.1
ELECTRICAL SPECIFICATIONS
Impedance
78 Ω
Nominal
Contact us by email:
sales@remingtonindustries.com
1/31/20 | -1 | Added Wire Services panel;
updated data sheet format to be
consistent with other data sheets | AG
DATE | ISS. | REVISION | BY
WIRING SCHEMATIC
Voltage
Rating
400 VRMS
Maximum
Temperature
Rating
-55°C (-67°F)
to
165°C (329°F)
Drawn by:
Checked by:
Drawing rev.:
AG 10/7/19
JH, LJ, DB
-1
3521 N. Chapel Hill Rd
Johnsburg, IL 60051 USA
很抱歉,暂时无法提供与“RCA-11-72”相匹配的价格&库存,您可以联系我们找货
