RB-LYN-212
RB-LYN-212
    LYNXMOTION
    TRI-TRACK CHASSIS KIT
RB-LYN-212 数据手册
Description  ● ● ● Robust interior/exterior tracked platform Can support 5lbs of payload Driven by two powerful DC gearmotors The Lynxmotion Tri-Track Chassis Kit is a robust Tracked Development Platform for your RC or autonomous robot experimentation. The robot is designed for indoor or outdoor use and performs well on many different surfaces. With the addition of the optional Base Rotate a robot arm or large sensor array can be added, or even a Johnny 5 style robot can be made! The chassis is designed to accept the ​Lynxmotion Mini Atom Bot Board V2​ and/or the Lynxmotion SSC-32 Servo Controller​ . There's room for the ​Dimension Engineering Sabertooth Dual 5A Regenerative Motor Driver​ motor controller and a new 12vdc 1600mAh Lynxmotion battery pack (Coming soon) with room to spare. The robot is capable of carrying up to a 5lb payload. SES arm mounted on Lynxmotion Tri-Track Chassis (Robot Arm sold separately) Lynxmotion Tri-Track Chassis used in Johnny 5 Combo Kit (sold separately) The Mechanics The robot chassis is made from ultra-tough laser-cut Lexan structural components, and custom aluminum brackets. By utilizing heavy duty polypropylene and rubber tracks with durrable ABS molded sprockets the robot has excellent traction. It includes two 12VDC gear head motors. What's Included  • Wiring Harness - Battery Connector • 2 x Gearhead Motor Connection Wire • Laser cut Lexan structural components • 2 x ​12VDC 120RPM 15oz-in GHM-02 Spur Gear Head Motor • 2 x Track - 2" Wide x 21 links ~23" (single) (TRK-01) • 6 x Track Sprocket - 6 Link (Pair) (SPRK-01) Useful Links  Web Site • ​Tri-Track Chassis Assembly Guide • ​Tracks Assembly Guide • ​Lynxmotion User and Assembly Guides Dimensions  Multimedia  https://www.youtube.com/watch?v=njkyA37yOr0&feature=emb_title
RB-LYN-212 价格&库存
很抱歉,暂时无法提供与“RB-LYN-212”相匹配的价格&库存,您可以联系我们找货
