TECHNICAL DATA SHEET
RPC-2.92
ADAPTOR
JACK - JACK
02K121-K00S3
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
Mechanically compatible with
RPC-3.50 and SMA
Documents
N/A
Material and plating
RF_35/08.06/4.0
Connector parts
Center contact
Outer contact
Dielectric
Material
Plating
Beryllium copper Gold, min. 1.27 μm, over chemical nickel
Stainless steel
Passivated
PS
Rosenberger Hochfrequenztechnik GmbH & Co. KG
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Tel.: +49 8684 18-0
Fax: +49 8684 18-499
email: info@rosenberger.de
Page
1/2
ADAPTOR
JACK - JACK
RPC-2.92
02K121-K00S3
Electrical data
Impedance
Frequency
Return loss
50 :
DC to 40 GHz
t 21 dB, DC to 40 GHz
Insertion loss
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage
Working voltage
RF-leakage
d 0.04 x f(GHz) dB
t 5 G:
d 3.0 m:
d 2.0 m:
750 V rms
250 V rms
t 100 dB up to 1 GHz
Mechanical data
t 500
t 22 N
1.70 Nm
0.80 Nm to 1.10 Nm
Mating cycles
Center contact captivation
Coupling test torque
Recommended torque
Environmental data
Temperature range
Thermal shock
Corrosion
Vibration
Shock
Moisture resistance
2002/95/EC (RoHS)
-40°C to +85°C
MIL-STD-202, Method
MIL-STD-202, Method
MIL-STD-202, Method
MIL-STD-202, Method
MIL-STD-202, Method
compliant
107,
101,
204,
213,
106
Condition
Condition
Condition
Condition
B
B
D
I
Tooling
N/A
Suitable cables
N/A
Packing
Standard
Weight
1 pce in box
3.0 g/pce
RF_35/08.06/4.0
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Herbert Babinger
06/12/04
Armin Maiwaelder
27/09/06
b00
06-0631
Manuela Fuehrich
27/09/06
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Tel.: +49 8684 18-0
Page
2/2
很抱歉,暂时无法提供与“02K121-K00S3”相匹配的价格&库存,您可以联系我们找货
