02K721-40MS3
02K721-40MS3
    ROSENBERGER
    2.92MM VERTICAL JACK PCB 40GHZ
02K721-40MS3 数据手册
Technical Data Sheet Straight Jack PCB RF_35/05.10/6.1 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG RPC-2.92 02K721-40MS3 Economic Solderless Connector All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to Mechanically compatible with IEC 61169-35 RPC-3.50 and SMA Documents PCB layout B 594A Material and plating Connector parts Center contact Outer contact Dielectric Material CuBe Stainless steel PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Gold, min. 1.27 µm, over chemical nickel Passivated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet Straight Jack PCB RPC-2.92 02K721-40MS3 Economic Solderless Connector RF_35/05.10/6.1 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Electrical data Impedance Frequency Return loss 50 Ω DC to 40 GHz ≥ 26 dB, DC to 26.5 GHz ≥ 23 dB, 26.5 GHz to 40 GHz Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage RF-leakage ≤ 0.04 x f(GHz) dB ≥ 5 GΩ ≤ 3.0 mΩ ≤ 2.0 mΩ 750 V rms 250 V rms ≥ 100 dB up to 1 GHz - Connector only, VSWR in application depends decisive on PCB layout - Mechanical data ≥ 500 ≤ 23 N ≥ 20 N 1.70 Nm 0.80 Nm to 1.10 Nm Mating cycles Mating force PCB side Center contact captivation Coupling test torque Recommended torque Environmental data Storage temperature range Operating temperature range Thermal shock Corrosion Vibration Shock Moisture resistance RoHS -40°C to +85°C -0°C to +85°C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 204, Condition D MIL-STD-202, Method 213, Condition I MIL-STD-202, Method 106 compliant Accessories Available Screws DIN 7985-H-A2 UNF 0-80 (cylinder head screw) for different PCB thickness. 3/16” length = Standard (already included with the connector) DIN7985-H-A2 UNF 0-80x3/16 1/4” length = Optional (PCB thickness min. 1.8 mm to max. 4.2 mm) DIN7985-H-A2 UNF 0-80x1/4 5/16” length = Optional (PCB thickness min. 3.2 mm to max. 5.7 mm) DIN7985-H-A2 UNF 0-80x5/16 3/8” length = Optional (PCB thickness min. 4.8 mm to max. 7.5 mm) DIN7985-H-A2 UNF 0-80x3/8 7/16” length = Optional (PCB thickness min. 6.4 mm to max. 8.9 mm) DIN7985-H-A2 UNF 0-80x7/16 Tooling N/A Weight 2.2 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date F. Reiner 16.02.16 M. Moder 26.03.17 a00 18-s133 M.Ruf 26.03.18 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
02K721-40MS3 价格&库存
很抱歉,暂时无法提供与“02K721-40MS3”相匹配的价格&库存,您可以联系我们找货
