Technical Data Sheet
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
RPC-3.50
Adaptor
03K121-K00S3
Jack - Jack
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
Mechanically compatible with
IEC 60169-23
RPC-2.92 and SMA
Documents
N/A
Material and plating
Connector parts
Center contact
Outer contact
Dielectric
Material
CuBe
Stainless steel
COP
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
Plating
Gold, min. 1.27 µm, over chemical nickel
Passivated
Tel. : +49 8684 18-0
Email : info@rosenberger.com
Page
1/2
RPC-3.50
Adaptor
Electrical data
RF_35/09.14/6.2
03K121-K00S3
Jack - Jack
Impedance
Frequency
Return loss
50 Ω
DC to 26.5 GHz
≥ 26 dB, DC to 26.5 GHz
Insertion loss
Insulation resistance
Proof voltage (at sea level)
Working voltage (at sea level)
RF-leakage
≤ 0.04 x f(GHz) dB
≥ 5 GΩ
1000 V rms
335 V rms
≥ 100 dB up to 1 GHz
Mechanical data
Mating cycles
Center contact captivation: axial
radial
Coupling test torque
Coupling torque recommended
≥ 500
≥ 27 N
≥ 0.01 Nm
1.70 Nm
0.80 Nm to 1.10 Nm
Environmental data
Temperature range
Thermal shock
Corrosion
Vibration
Shock
Moisture resistance
RoHS
-40 °C to +125 °C
MIL-STD-202, Meth. 107, Cond. B
MIL-STD-202, Meth. 101, Cond. B
MIL-STD-202, Meth. 204, Cond. D
MIL-STD-202, Meth. 213, Cond. I
MIL-STD-202, Meth. 106
compliant
Tooling
N/A
Suitable cables
N/A
Weight
6.2 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Herbert Babinger
11.05.04
H. Babinger
04.03.21
d00
20-1016
A. Youmsi
04.03.21
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
Page
2/2
很抱歉,暂时无法提供与“03K121-K00S3”相匹配的价格&库存,您可以联系我们找货
