05AS122-K40S3
05AS122-K40S3
    ROSENBERGER
    N-Type In-Line Module
    PRECISION N TYPE ATTENUATOR
05AS122-K40S3 数据手册
Technical Data Sheet RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG RPC-N 50 Ÿ Attenuator 05AS122-K40S3 Plug/Jack All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 61169-16 Documents Application note AN001 “Calibration Services” Documentation This Part is delivered with: • USB Stick with S2p data file of the reference measurement values. Calibration Certificate as PDF file. • Calibration Certificate Details see ”Declaration of calibration” options. Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/3 Technical Data Sheet RPC-N 50 Ÿ Attenuator 05AS122-K40S3 Plug/Jack RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG Material and plating Connector parts Center conductor - plug Center conductor - jack Outer conductor Coupling nut Dielectric Substrate Material CuBe CuBe Stainless steel Stainless steel PPE Al2O3 Plating Gold, min. 1.27 μm, over nickel Gold, min. 1.27 μm, over nickel Passivated Passivated Electrical data Frequency range DC Resistance Power handling DC to 18 GHz 50 Ω ≤ 0.5 W Electrical data (typical) ≥ 32 dB, DC to 4 GHz ≥ 23 dB, 4 GHz to 18 GHz 40 dB ± 0.5 dB, DC to 4 GHz 40 dB ± 1.0 dB, 4 GHz to 18 GHz Return loss Attenuation Mechanical data ≥ 500 1.70 Nm 1.10 Nm 5.28 mm to 5.32 mm 5.22 mm to 5.26 mm Mating cycles Maximum torque Recommended torque Gauge - plug Gauge - jack Electrical verification standard This Attenuator is designed as an electrical verification standard. Reference measurement values (calibration results) for transmission and reflection are included. Connected to a calibrated VNA the actual measured transmission and reflection values can be compared to the reference measurement values and the quality of the VNA calibration can be evaluated. Environmental data 1 Operating temperature range 2 Rated temperature range of use Storage temperature range + 20 °C to +26 °C 0 °C to +50 °C - 40 °C to +85 °C RoHS compliant 1 2 Temperature range over which the reference measurement values are applicable. This range is underneath and above the operating temperature range, within the attenuator is fully functional and could be used without damage. Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/3 Technical Data Sheet RPC-N 50 Ÿ Attenuator 05AS122-K40S3 Plug/Jack Declaration of calibration options RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG Factory Calibration Standard delivery for this verification standard includes a Factory Calibration. The Calibration Certificate issued reports individual calibration results. Reflection results are traceable to national / international standards. A S2p data file with the reference measurement values is included. Accredited Calibration Not available. For further, more detailed information see application note AN001 on the Rosenberger homepage. Calibration interval Recommendation 12 months Packing Standard Weight 1 pce in box 68.0 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Kerstin Herzog 20.01.05 Markus Müller 12.10.16 h00 16-1390 Marion Striegler 12.10.16 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 3/3
05AS122-K40S3 价格&库存
很抱歉,暂时无法提供与“05AS122-K40S3”相匹配的价格&库存,您可以联系我们找货
