B2BK102-40ML5
B2BK102-40ML5
    ROSENBERGER
    VIA STRAIGHT JACK PCB
B2BK102-40ML5 数据手册
Technical Data Sheet - Draft RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ƔThis document is protected by copyright ƔRosenberger Hochfrequenztechnik GmbH & Co. KG VIA B2BK101-400L5 Straight Jack PCB All dimensions are in mm; tolerances acc. to ISO 2768 m-H Interface According to Rosenberger B2B-VIA Documents Panel piercing B 567 Material and plating Connector parts Center contact Outer contact Dielectric inner Dielectric outer Material CuBe or equiv. CuBe or equiv. LCP PA Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated AuroDur®, gold plated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet - Draft VIA B2BK101-400L5 Straight Jack PCB RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ƔThis document is protected by copyright ƔRosenberger Hochfrequenztechnik GmbH & Co. KG Electrical data Impedance Frequency Return loss* 50 : DC to 6 GHz 36 dB typ. @ DC to 2.5 GHz 35 dB typ. @ 2.5 GHz to 4 GHz 32 dB typ. @ 4 GHz to 6 GHz Insertion loss d 0.1 x Insulation resistance Center contact resistance Outer contact resistance Test voltage (at sea level) Working voltage (at sea level) Power handling (sea level, VSWR 1.0) t 5 G: d 6 m: d 5 m: 500 V rms 335 V rms 260 W @ 2.2 GHz (at 20 °C) (tbd) 160 W @ 2.2 GHz (at 100°C) (tbd) 130 W @ 2.7 GHz (at 100°C) (tbd) d 2A DC t 70 dB up to 6 GHz Contact Current Screening Attenuation f [GHz] dB - Connector only, VSWR in application depends decisive on PCB layout – * depending on the axial misalignment Mechanical data t 100 t7N ¨ 5N (between Limited Detent and Smooth Bore) 2 mm (± 1 mm) ± 0.6 mm / 4° (tbd) t 6.5 mm Mating cycles Center contact captivation Disengagement force Working range Radial misalignment Pitch Environmental data Temperature range Thermal shock Climatic category Moisture resistance Vibration Shock Max. soldering temperature RoHS -55 °C to +125 °C MIL-STD-202, Method 107, Condition B IEC 61169-1, Sub-clause 9.4.5 (+155 °C, 250 hours) MIL-STD-202, Method 106 MIL-STD-202, Method 204, Condition B MIL-STD-202, Method 213, Condition A IEC 61760-1, +260°C for 10 sec. compliant Weight Weight 0,32 g/pc (tbd) While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date B. Aicher 20.10.15 B. Aicher 08.09.16 400 16-v344 A_Wallner 08.09.16 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
B2BK102-40ML5 价格&库存
很抱歉,暂时无法提供与“B2BK102-40ML5”相匹配的价格&库存,您可以联系我们找货
