DATA SHEET
Very High Performance Single-Phase
Filters FN2520
Low Profile - High performance, EMC/EMI filter
Excellent EMC filter for robotics, datacenters
and a variety of other applications
Approvals & Compliances
Available terminals: Fast-on, wire leads, bolt
and clamps
Voltage rating up to 277 VAC / 400 VDC
Fits within 1 height unit (HU) of a 19" rack
application
50°C operating temperature
2-stage filter performance
Features and Benefits
FN2520 series fits perfectly within 1HU height for
rack mount applications
The filters are built to perform perfectly in
datacenter and audio video equipment
The shape allows convenient and space-saving
installation
Fulfills the requirements in IEC/EN 62040-1 Uninterruptible power systems (UPS)
Performance indicators
high
standard
FN2500
very high
FN2520
Rated current [A]
10
32
Fulfills the requirements in IEC 62368-1 - Audio/
Video, Information and Communication
Technology Equipment
Fulfills the requirements in IEC/EN 60335-1 Household and similar appliances
Typical Applications
Datacenter (at 400 VDC)
Building technology with DC power distribution
Robotics, collaborative robots, autonomous
machines
Audio and video equipment
Technical Specifications
UPS - Uninterruptible power supplies
Rated operating voltage
277 VAC / 400 VDC (CQC: 250 VAC / 250 VDC)
Operating frequency
DC to 60 Hz
Rated currents
10 to 32 A @ 50°C
Overload capability
1.5 x rated current for 1 minute once per hour
Cooling
Natural cooling AN
Climatic category
FN2500: 40/100/21 acc. IEC60068-1
Flammability corresponding to
Plastic material: UL 94 V0
Laces for -07 version: UL 94 VW1
Surge withstand
2 kV Ph-Ph / 4 kV Ph-PE (Level 4)
High potential test voltage
P(DC+) –> N(DC-) 1500 VDC for 2 sec*
P(DC+)/N(DC-) –> PE 2500 VDC for 2 sec*
Altitude
Derating above 2000 m
Certified to
UL/IEC 60939-3, CSA 22.2 No. 8-13, GB/T 15287
MTBF
> 300,000 h
Protection category
IP00 / IP20 for -103 terminals
Pollution degree
2 acc. IEC 60664-1
Vibration and shock
3M12 acc. IEC 60721-3-3
Overvoltage category
II acc. IEC 60664-1
Temperature range (operation and storage)
FN2500: -40°C to +100°C (with derating >50°C)
FN2520: -40°C to +85°C (with derating >50°C)
High potential test voltage: Repetition with max. 80% of specified values
Typical electrical schematic
1
L1
L2
1
2
2
2
Very High Performance Single-Phase Filters
Schaffner Group
DATA SHEET
27. Sep 2022
Filter Selection Table
Filter
Rated
current
Leakage
current*
@ 50°C
(@ 40°C)
@ 277 VAC/50
Hz
Power
Inductance**
loss
Capacitance** Resistance**
@ 25°C
L1
L2
Cx1
Cx2
Cy1
Cy2
R
Weight
max****
Connections***
line side/load side
(@ 120 VAC/60
Hz)
[A]
[mA]
[W]
[mH]
[mH]
[μF]
[μF]
[nF]
[nF]
[kΩ]
[kg]
FN2520-10-yyC1111
10 (11)
0.82 (0.43)
8.0
8.3
8.3
1
0.47
4.7
4.7
680
-05
-07
-08
-103
0.4
FN2520-15-yyC1111
15 (17)
0.82 (0.43)
9.0
4.0
4.0
1
0.47
4.7
4.7
680
-05
-07
-08
-103
0.4
FN2520-20-yyC1111
20 (22)
0.82 (0.43)
8.4
2.4
2.4
1
0.47
4.7
4.7
680
-05
-07
-08
-103
0.5
FN2520-25-yyC1111
25 (27)
0.82 (0.43)
11.0
1.5
1.5
1
0.47
4.7
4.7
680
n.a
-07
-08
-103
0.5
FN2520-32-yyC1111
32 (35)
0.82 (0.43)
13.2
0.9
0.9
1
0.47
4.7
4.7
680
n.a
-07
-08
-103
0.4
Two-stage
* Maximum leakage current under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage current could reach twice this level.
** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%.
*** Standard parts have same input and output connections. For combinations, please contact your sales representative.
**** Weight depending on choice of connectors.
Product selector
FN2520-xx-yy-C1111
yy – Line / load terminal types
05:
07:
08:
103:
fast-on 6.3 x 0.8 mm (up to 20 A only)
wire leads
M4 screw
push-in terminal
xx – Rated current
10-32:
10 A – 32 A
3
Schaffner Group
DATA SHEET
27. Sep 2022
Typical Filter Attenuation
Per CISPR 17: symmetrical 50 Ω/50 Ω -> Differential Mode (DM); asymmetrical 50 Ω/50 Ω -> Common Mode (CM)
FN2520 - Two-stage filter
Hz
Hz
FN2520-15-yy-C1111
FN2520-10-yy-C1111
FN2520-25-yy-C1111
FN2520-20-yy-C1111
Hz
Hz
FN2520-32-yy-C1111
Hz
4
Schaffner Group
DATA SHEET
27. Sep 2022
Dimensions FN2520 - 10 A To 32 A - Two-stage Filter
For dimensions [mm] without tolerances: ISO2768-cL/EN22768-cL applies
LINE
LOAD
if not otherwise stated, load side dimensions apply
T E RM I NA L - 0 5
8.5
33.7
10 +- 01
BU
BN
35
BU
14.4
BN
14.4
27
200
GN YE
14.6
35
7.4
33.7
8.5
27.9
TERMINAL -07
12.3
15.9
15.9
30.9
6.3x0.8
33.7
8.4
35
M4, Torque = 1.2 - 1.3 Nm
14.4
14.4
9.6
25
8.4
25
17.6 1
18.4
18.4
7.5
7.5
Terminal -103 connection capacity:
solid or stranded
0.2 - 10 mm / AWG 24 - 8
stripping length =11-13 mm
L OA D
LINE
51
2
128
149.4
33.2
4 .2
11
HF grounding
4.
32.3
23
35
10.2
27.9
TERMINAL -103
25
73
27.9
TERMINAL -08
10.2
10.7
5
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C No 565 Chuangye Road Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93 Miniparc III Edificio E El
Soto de Moraleja Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
27. Sep 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780 37FL 98 North-Sathorn Rd Silom
Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN2520-25-08-C1111”相匹配的价格&库存,您可以联系我们找货
