DATASHEET
IEC Inlet Filters FN 9274
Versatile Medical Class II EMC/EMI Filter
Medical filter suitable for compliance with
Protection Class II (ME) according IEC 60601-1
Approvals & Compliances
Fulfills the requirement for two MOPP (means
of patient protection), compliant with IEC/EN
60601-1
No leakage current to earth
Rated currents up to 15 A
Excellent performance/size ratio
Front mount, rear mount and snap-in versions
(B, MB and S1B type)
Plastic enclosure for higher dielectric strength
insulation
Fast-on terminals or wire leads
V-lock compatible
The FN9274 IEC inlet filter is suitable for compliance
with Class II ME equipment. It incorporates an EMC
filter into a C18 IEC inlet that offers excellent filter
attenuation in a compact housing.
The filter is available with two connection variants on
the load side. The cable version is touch-safe by
default. The pins of the fast-on-version are recessed in
the plastic housing. In combination with insulated
crimp connectors Class II compliance can be
achieved for Fast-on version.
The requirements for Two MOPP in IEC 60601-1:2005
+ A1 regarding Leakage Currents, Insulation and Air
Clearance and Creepage Distances and Ball Pressure
test are fulfilled.
Performance indicators
Features and benefits
Suitable for class II Medical Equipment (ME)
15
Fulfills the requirements for Two MOPP in IEC
60601-1 - Medical electrical equipment
Fulfills the requirements in IEC/EN 62368-1 - Audio/
video, information and communication technology
equipment
Technical specifications
Fulfills the requirements in IEC/EN 60950-1 Information technology equipment
Temperature range (operation and storage)
Design corresponding to
-40°C to +100°C (40/100/21)
Protection category
IP 40 according to IEC 60529 (front side, with inserted
plug)
Overvoltage category
Pollution degree
Vibration and shock
MTBF @ Rated amb. Temp./Voltage (MilHB-217F)
II acc. IEC 60664-1
Flammability corresponding to
Plastic Material: UL 94 V-0
Laces for -07 version: UL 94 VW-1
1 to 15 A @ 40°C max.
DC to 400 Hz
P –> N 760 VAC for 2 s
P/N –> Ext. insulation 4 kVAC for 60 s acc. IEC 60601-1
up to 15A: UL 60939-3, CSA Std C22.1 No. 8-13
up to 10A: IEC/EN 60939-3, GB/T15287, GB/T15288
2 acc. IEC 60664-1
3M4 acc. IEC 60721-3-3
> 1,000,000 hours
Fulfills the requirements in IEC/EN 60335-1 Household and similar electrical appliances
Fulfills the requirements for Reinforced Insulation in
IEC 61010-1 - Safety requirements
All versions certified according UL/IEC 60939-3,
C22.2 No. 8. CQC/CCC GB/T15287 and GB/T15288
Typical applications
General medical devices (MDD)
In-vitro diagnostic medical devices (IVDD)
Test and measurement equipment
Portable electrical and electronic equipment
Single-phase power supplies, switch-mode power
supplies (SMPS)
Audio / video / communication equipment (IEC/UL
62368-1)
Electrical schematic
Cx R
2x L1
N
N'
P
P'
LOAD
250 VAC, 50/60 Hz
LINE
Maximum continuous operating voltage
Rated currents
Operating frequency
High potential test voltage
2
Schaffner Group
EMC/EMI Products
Datasheets
26 Aug 2020
Filter selection table
Filter
Rated current
Leakage current
@ 40°C
Inductance
Capacitance
Resistor
Input
Output
L1
Cx
R
connections
connections
Weight
[A]
[mA]
[mH]
[µF]
[MΩ]
FN9274XXB-1-ZZ
1
0.0
41.1
0.22
1
FN9274XXB-2-ZZ
2
0.0
20.1
0.22
1
C18
-05
-07
很抱歉,暂时无法提供与“FN9274B-4-05”相匹配的价格&库存,您可以联系我们找货
