Grove - Digital Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F)(P)
SKU 101020578
Grove - Digital Distance Interrupter 0.5 to 5cm is an infrared proximity sensor module
based on GP2Y0D805Z0F. Normaly the output of this sensor is 1(High), when the
object enters the measurement range of the sensor, it will be triggered and output a
0(LOW).At the same time the on-board LED will light up. As the name suggests, the
measurement range is from 0.5cm to 5cm.
There are two types of Grove - Digital Distance Interrupter 0.5 to 5cm: Grove - Digital
Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F) and Grove - Digital Distance
Interrupter 0.5 to 5cm(GP2Y0D805Z0F)(P). For the version without letter P, the lens
and the grove interface are at the same side; for the version with letter P, the lens and
the grove interface are at the different sides. As you can see, this module is the 'P'
version, if you want the lens and the grove interface at the same side, please click
the Grove - Digital Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F)
GP2Y0D805Z0F is a distance measuring sensor unit, composed of an integrated
combination of PD(photo diode) , IRED (infrared emitting diode) and signal processing
circuit. The variety of the reflectivity of the object, the environmental temperature and
the operating duration are not influenced easily to the distance detection because of
adopting the triangulation method.
Features
Easy to use
Integrated indicator LED
Digital output
High anti-interference
Applications
Touch-less switch (Sanitary equipment, Control of illumination, etc.)
Robot cleaner
Technical Details
Dimensions
40mm x 20mm x 11mm
Weight
G.W 9.70g N.W 3.80g
Battery
Exclude
Trigger Range
0.5cm ‐ 5cm
Working voltage
3.3V/5V
Operating temperature
‐10 ‐‐ 60
Part List
Grove ‐ Digital Distance Interrupter
1
Grove cable
1
ECCN/HTS
ECCN
EAR99
HSCODE
9031900090
https://www.seeedstudio.com/Grove‐Digital‐Distance‐Interrupter‐0‐5‐to‐5cm‐GP2Y0D805Z0F‐‐p‐3085.html 8‐21‐18
很抱歉,暂时无法提供与“101020578”相匹配的价格&库存,您可以联系我们找货
