Grove - Turbidity Sensor (Meter) for Arduino V1.0
SKU 101020752
Grove - Turbidity Sensor can measure the turbidity of the water.
Key Features
Low power consumption
Small size: 2.0cm x 4.0cm Grove module
Only 3 pins needed, save I/O resources
Easy to use: Grove connector, plug and play
Output mode optional, support analog output and digital output
Description
The Grove turbidity sensor can measure the turbidity of the water (the number of
suspended particles).
The optical sensor of this module can measure the density of turbid water and the
concentration of extraneous matter using the refraction of wavelength between photo
transistor and diode. By using an optical transistor and optical diodes, an optical sensor
measures the amount of light coming from the source of the light to the light receiver, in
order to calculate turbidity of water.
The output mode can be selected by adjusting the switch on the board. Supports analog and
digital output. The sensitivity can be adjusted by the on-board knob.
Specification
Operating Voltage: 3.3V/5V DC
Output Interface: Analog/Digital
Connector: 1 Grove, 1 power interface
LEDs: 1 power LED, 1 signal LED
Switch: 1 A-D toggle switch
Dimensions: 20x40 mm
Typical Application
Measure the water pollution degree of washing machines such as dishwashers to determine the
optimal washing time and rinsing times.
Industrial site control.
Environmental sewage collection.
Hardware Pinout
Part List
1 x Grove Turbidity Sensor
1 x Sensor Probe
1 x 20cm Grove Cable
1 x Connecting Cable
Note
We are going to bring new add-ons to extend functionalities based on the community needs, so we are
looking forward to any suggestions you guys have! Let us know in the forum, we will carefully listen to
and take action!
ECCN/HTS
HSCODE
UPC
9027900000
https://www.seeedstudio.com/Grove-Turbidity-Sensor-p-4399.html/1-24-20
很抱歉,暂时无法提供与“101020752”相匹配的价格&库存,您可以联系我们找货
