Sipeed Longan Nano - RISC-V GD32VF103CBT6
Development Board
SKU 102991302
Sipeed Longan Nano is a development board based on GD32VF103CBT6 MCU with RISC-V
32-bit core of GigaDevice. It is convenient for students, engineers and geek enthusiasts to
contact the new-generation RISC-V processor. Longan Nano sold by Seeed comes
with a 0.96inch 160x80 IPS RGB LCD and an acrylic transparent case.
GD32VF103CBT6 is a Bumblebee core based on Nuclei System Technology. Support
RV32IMAC instruction set and ECLIC fast interrupt function. Core power consumption is
only 1/3 of that of traditional Cortex-M3.
Longan Nano development board, double-row pin layout design, needle spacing 700 mil,
can be inserted directly into breadboard; on-board 8M passive crystal oscillator, 32.768
KHz RTC low-speed crystal oscillator, Mini TF slot, and use Type-C USB interface.
Longan Nano supports multiple download methods: USB DFU download, UART ISP
download, JTAG download. In the USB DFU download mode, you only need a USB Type-C
cable to download the program to the development board. At the same time, Longan Nano
supports the standard JTAG interface, which can be debugged online using the in-store
RISC-V debugger or any JTAG-enabled debugger such as J-Link.
Meanwhile, Sipeed has adapted the PlatformIO IDE for the Longan Nano development
board, which can be visually developed on multiple platforms such as Windows/Linux:
https://github.com/sipeed/platform-gd32v
Features
Chip built-in 128KB Flash, 32KB SRAM
4 x general purpose 16-bit timer, 2 x basic 16-bit timer, 1 x advanced 16-bit timer
Watchdog, RTC, Systick
3 x USART, 2 x I2C, 3 x SPI, 2 x I2S, 2 x CAN, 1 x USBFS (OTG)
2 x ADC (10 channel), 2 x DAC
specifications
SPECIFICATION
CPU
GD32VF103CBT6 based on RISC-V 32-bit core
Kernel power
consumption
Only 1/3 of the traditional Cortex-M3
Chip built-in
Peripheral
● 4 x general purpose 16-bit timer, 2 x basic 16-bit timer, 1 x advanced 16bit timer
● Watchdog, RTC, Systick
● 3x USART, 2 x I2C, 3 x SPI, 2 x I2S, 2 x CAN, 1 x USBFS (OTG),
● 2 x ADC (10 channel), 2 x DAC
SOFTWARE
IDE
PlatformIO IDE, Support debugging, Arduino
Compile Toolchain &
Debugger
GCC, OpenOCD
Operating system
RT-Thread、LiteOS
HARDWARE
Storage expansion
Short body TF card slot
Display expansion
8pin 0.5mm FPC Block Expansion 160x80 RGB IPS LCD (SPI Interface)
Debug interface
2x4 pin leads to JTAG debug interface
Connector
Double row 2.54 pitch pin
Crystal
8MHz Passive High Speed Crystal +32.768KHz Low Speed RTC Crystal
Dimension
Part List
Part List
Sipeed Longan Nano Development Board
x1
x1
Acrylic transparent case
x1
ECCN/HTS
ECCN
3A991.a
HSCODE
8543709990
UPC
Documents
Wiki
Resource Download
GD32VF103_User_Manual_EN_V1.0.pdf
GD32VF103_Datasheet_Rev1.0.pdf
Bumblebee core datasheet_en.pdf
Bumblebee core intro_en.pdf
Bumblebee kernel instruction set documentation
Github
SDK
HDK
https://www.seeedstudio.com/Sipeed-Longan-Nano-RISC-V-GD32VF103CBT6-Development-Board-p-4205.html/9-13-19
很抱歉,暂时无法提供与“102991302”相匹配的价格&库存,您可以联系我们找货
