MAKER MDD3A ‐ Dual channel 3A DC Motor Driver
SKU 105090004
Are you interested in the robot motor? Do you want to start a motor driver? Here is your
chance! Dual channel 3A DC Motor Driver is a powerful motor driver which can support
two brushed DC motors or one single bipolar/unipolar stepper motor from 4V to 16V. This
motor driver is designed with discrete MOSFETs H-bridge. As a matter of fact, the motor
driver is able to run with 3Amp current per channel continuously without any additional
heatsink.
There are two groups of test buttons(each group contains two buttons) to correspond with
two separated channels. With these test buttons, you don’t have to connect with the
controller to test the driver, which is very convenient. The module also provides 4V~5V
output to support the controller.
Dual channel 3A DC Motor Driver is able to run with a wide power supply of 1.8V to 12V.
What ‘s more? It can be compatible with many controllers, such as Arduino and raspberry
pi. Besides, this driver support reverse polarity protection, so it will not be broken easily by
misoperation.
Features
Bidirectional control for two brushed DC motor.
Control one unipolar/bipolar stepper motor.
Operating Voltage: DC 4V to 16V
Maximum Motor Current: 3A continuous, 5A peak
Buck-boost regulator to produce 5V output (200mA max).
Buttons for quick testing.
LEDs for motor output state.
Inputs compatible with 1.8V, 3.3V, 5V and 12V logic (Arduino, Raspberry Pi, PLC, etc).
PWM frequency up to 20kHz (Output frequency is same as input frequency).
Reverse polarity protection
Interface
ECCN/HTS
HSCODE
UPC
8503001000
https://www.seeedstudio.com/MDD3A‐p‐4274.html/11‐19‐19
很抱歉,暂时无法提供与“105090004”相匹配的价格&库存,您可以联系我们找货
