Driver Breakout for micro:bit, drives motors and servos
SKU 105990091
Description
This driver board gives your micro:bit the ability to drive two channel DC motors and three
channel servos. It's an ideal choice for you to DIY mobile robots.
Features
micro:bit edge connector, directly pluggable
2x DC motor interfaces, 3x servo interfaces
Integrates 5V regulator, up to 3A output current, can be powered from battery through VIN
terminal
Onboard multi connector options for DC motors in different specifications, onboard standard
servo headers
Comes with development resources and manual (micro:bit graphical examples)
Micor:bit has variety of programming methods like mbed, micropython, typescript and other
programming methods, as well as code online websites which are abundant.
The official recommendation are two programming methods: typescript and micropython.
Typescript is the graphical programming language. Its website is
that:https://makecode.microbit.org/#
Technical Details
Dimensions
65mm x 36mm x 15mm
Weight
G.W 219g N.W 200g
Battery
Exclude
Power supply
6V~12V (VIN terminal)
Servo voltage
5V
Logic voltage
3.3V
Driver
TB6612FNG
Mounting hole size
3.0mm
Pinouts
Vcc
Power (6~12V)
GND
Ground
A1
positive pole of motor A
A2
negative pole of motor A
B1
positive pole of motor B
B2
negative pole of motor B
P0
control pin P0 of steering gear
P1
control pin P1 of steering gear
P2
control pin P2 of steering gear
Part List
Motor Driver for micro:bit
1
ECCN/HTS
ECCN
EAR99
HSCODE
8503001000
https://www.seeedstudio.com/Wio%20LTE%20EU%20Version%20v1.3%204G,%20Cat.1,%20GNSS,%20Espruino%20Compatible‐p‐3212.html/12‐4‐18
很抱歉,暂时无法提供与“105990091”相匹配的价格&库存,您可以联系我们找货
