109990365
    SEEED(矽递科技)
    通信系统,计算机系统,电气系统 逻辑分析器
109990365 数据手册
            MiniDSO LA104 Logic Analyzer  SKU 109990365    LA104 is a compact, portable logic analyzer with a display screen. It is widely applied to avariety  of industries and fields, such as automotive electronics, communication, power supply and  computer.    Logic analyzer is used to analyze the logic relationship of digital systems, as it can collect and  store multichannel digital signals and directly display their sequential relationship on the  screen. The logic analyzer is equipped with the function of protocol analysis, and can parse logic  signal of the protocol's physical layer into data of the high layer protocol and display them on  the screen.         Features:  Color display  4 Input Channels  100MHz Max Sampling Rate  100MHz Measuring Bandwidth  Built In 8MB Flash Storage          Technical Details    Dimensions 150mm x 103mm x 40mm  Weight  G.W 175g     N.W 168g    Battery  Exclude  Measuring Input Parameters  Channel  4  Max Sampling Rate  100M Sa/S  Min Captured Pulse width  10ns  Input Voltage Range  0‐5V  Equivalent Input Impedance  1MΩ  Threshold Voltage  1.2‐3V  Output Parameters    Programmable Output Channel  4  Programmable Output Type  PWM,SPI,I2C,UART  Programmable Output Amplitude  3v  3V Power Output Channel  1  Storage  Built‐in 8M Flash Storage  Battery  Built‐in 500mAh Lithium Battery    Display  2.8 ’ Color LCD Screen  Size  100mm*56.6mm*8.4mm  Part List  Logic Analyzer 1  Hooks  5  Dupont Cables  20  Safety Instructions  1  ECCN/HTS  ECCN Not Available                   https://www.seeedstudio.com/MiniDSO LA104 Logic Analyzer‐p‐3217.html 12‐4‐18
109990365 价格&库存
很抱歉,暂时无法提供与“109990365”相匹配的价格&库存,您可以联系我们找货
