110090162
    SEEED(矽递科技)
    ROBOBLOQ QOOPERS 6-IN-1 TRANSFOR
110090162 数据手册
Robobloq Qoopers 6-in-1 Transformable Robot Kit SKU 110090162 Description The best designed platform to learn robotics and programming. Do you want to build your own robot, but hate the wriggling cables and the rugged circuit boards? Then you'll like Qoopers. Qoopers is a transformable robot with extensive DIY capacity, and is made with anodized aluminium to have a mature look. Qoopers is also an expanding aluminium construction platform. You can build your own robots with growing options of sensors and parts, and go endless with your imagination. Transformable Before you start to build, pick your favorite character to begin with! Qoopers has 6 members and each of them has different look and functions! And of course you can build any other forms as you want! App Control Meet the Robobloq app, the playground for everything about Qoopers. In the app, you can find assembling instructions for each official form. You can control Qoopers to move, play sounds, make faces, or even act to your programs! Face Expressions Qoopers has emotions, and apart from the presets, you can define more emotions using the LED Dots Matrix Customizing interface. Obstacle Avoiding Relax and just play! The ultrasonic sensor contributes to an obstacle avoiding mode. You're not going to hurt your Qoopers, or your furnitures. Drag-and-Drop Programming The easiest programming environment EVER! The"My Application"center is a graphical programming environment based on Scratch 3.0. You can not only control Qoopers' actions in sequence, you can also use variables and loop commands to create sophisticated programs. Lego Compatibility Pick up your Lego blocks and play them the new way! Stack them on Qoopers and make a colorful robot! Specs Parts List Technical Details Dimensions 248mm x 214mm x 166mm Weight G.W 1800g Battery Exclude Part List Robobloq Qoopers 6-in-1 Transformable Robot Kit 1 https://www.seeedstudio.com/Robobloq-Qoopers-6-in-1-Transformable-Robot-Kit-p-3020.html1-11-18
110090162 价格&库存
很抱歉,暂时无法提供与“110090162”相匹配的价格&库存,您可以联系我们找货
