Grove ‐ UART WiFi V2 (ESP8285)
SKU 113020011
Description
Grove ‐ UART WiFi V2.0(ESP8285) is a serial transceiver module featuring the ubiquitous
ESP8285 IoT SoC. With integrated TCP/IP protocol stack, this module lets your
microcontroller interact with WiFi networks with only a few lines of code. Each ESP8266
module comes pre‐programmed with an AT command set firmware, meaning you can send
simple text commands to control the device. The SoC features integrated WEP,
WPA/WPA2, TKIP, AES, and WAPI engines, can act as an access point with DHCP, can join
existing WiFi networks and has configurable MAC and IP addresses.
It's the upgrade version of Grove ‐ UAUT WiFi, we changed the ESP8266 into ESP8285, and
made some other adjustments to make it more stable and lighter. For more detail about the
version change, please refer to our wiki.
ESP8285 can perform either as a standalone application or as the slave to a host MCU.
When ESP8285 hosts the application, it promptly boots up from the flash. The integrated
high‐speed cache helps to increase the system performance and optimize the system
memory. Also, ESP8285 can be applied to any micro‐controller design as a Wi‐Fi adaptor
through SPI/SDIO or I2C/UART interfaces.
Features
Grove 4‐pin connector (RX,TX,VCC,GND)
802.11 b/g/n protocol (2.4GHz)
WiFi Direct (P2P), soft‐AP
Supports three modes: AP, STA and AP+STA coexistence mode
Integrated TCP/IP protocol stack
LwIP (lightweight IP)
Integrated low power 32‐bit CPU could be reprogrammed as an application processor
Serial UART Interface
Multi‐queue QoS management
Wake up and transmit packets in < 2ms
Onboard ceramic antenna
Reset switch
32‐bit processor
On‐chip SRAM
1 MB build‐in SPI flash
Part List
1
Grove cable
1
Technical Details
Weight
G.W 8g N.W 3.4g
Battery
Exclude
Input voltage
3V / 5V
Baud Rate
115200
Chip
ESP8258 ESP‐07 SoC
AT Firmware
esp_iot_sdk_v1.1.0
Interface
SDIO 1.1/2.0, SPI, UART
Five power states
OFF, DEEP_SLEEP, SLEEP, WAKEUP and ON
Consumption
Standby power consumption of
很抱歉,暂时无法提供与“113020011”相匹配的价格&库存,您可以联系我们找货
