113060002
    SEEED(矽递科技)
    PROJECT KIT LIGHTING XADOW DUINO
113060002 数据手册
RePhone Lumi Kit SKU 113060002    Slim and small modulesPowered by Xadow GSM+BLE Programmable LED Driver Various rich-featured add-on modules for function extension Description RePhone Lumi Kit is specially designed for LED lovers - embedding the Xadow GSM+BLE module into your awesome lighting device and control the light via SMS or Bluetooth! TheXadow Duino is specially designed for building up awesome Lighting Devices using the most popular RGB LED WS2812b. Based on the MCU ATmega32u4 and the built-in micro USB, Xadow Duino allows you to either control the RGB LEDs directly from the software in RePhone Kit Create, or program the board with Arduino IDE to make it work dependently. FEATURES  • Slim and small modules  • Powered by Xadow GSM+BLE  • Programmable LED Driver  • Various rich-featured add-on modules for function extension  • Stackable, chainable and sewable with other Xadow Modules SPECIFICATION  • Core Module: Xadow GSM+BLE  • Microcontroller: MT2502  • MCU Core: 32-bit ARM7EJ-STM RISC processor  • RAM: 4MB  • Flash Memory: 16MB  • Power Supply: 3.3 – 4.2V  • Power Consumption: 20mW/30mW/52mW @ standby(no radio)/standby(GSM)/standby(BT)  • Quad-band: 850/900/1800/1900 MHz  • GPRS: Class 12 modem  • Clock Speed: 260 MHz  • Connector: 35 PIN Connector & 11 PIN Connector for Xadow, SMD Female JST battery connector  • Interfaces: External ports for LCD, camera, I2C, SPI, UART, and GPIOs etc.  • Dimension: 25.37mm X 20.30mm / 1" X 0.8" PART LIST  • Xadow GSM+BLE * 1  • Xadow Duino * 1  • Xadow GSM Breakout * 1  • FPC Cable 35 PIN * 2  • FPC Cable 11 PIN * 2  • Battery 520mAh * 1  • User Guide * 1 RePhone Lumi Kit Introduction RePhone Lumi Kit is specially designed for LED lovers - embedding the Xadow GSM+BLE module into your awesome lighting device and control the light via SMS or Bluetooth! Specification Xadow GSM+BLE Microcontroller MT2502 MCU Core 32-bit ARM7EJ-STM RISC processor RAM 4 MB Flash Memory 16 MB Power Supply 3.3 ~ 4.2V(no SIM)/3.5 ~ 4.2V(with SIM) Power Consumption 20mW/30mW/52mW @ standby(no radio)/standby(GSM)/standby(BT) Quad-band 850/900/1800/1900 MHz GPRS Class 12 modem Clock Speed 260 MHz Connectors 35 PIN Connector & 11 PIN Connector for Xadow Modules; JST 1.0 Connector for the battery Interfaces LCD, Audio, I2C, SPI, UART, and GPIOs etc Dimensions 25.37mm × 20.30mm / 1” × 0.8” Xadow Duino Microcontroller ATmega32u4 Power Supply 5V via USB, current draw is 1.5A at Max 3.3 ~ 4.2V via battery socket, current draw is 1.5A at Max 3.3 ~ 6V via breakout pins, current draw is 500 mA at Max 3.3 ~ 4.2 V via Xadow GSM+BLE, current draw is 500 mA at Max Charging Current 500 mA Flash Memory 32 KB (ATmega32u4) of which 4 KB used by bootloader SRAM 2.5 KB (ATmega32u4) EEPROM 1 KB (ATmega32u4) Clock Speed 16 MHz Connector 2 × 11 PIN Xadow Connector Bonding pads for RGB LED WS2812b Interfaces Interface with Xadow GSM+BLE through I2C (7-bit address 0x23) Dimensions 25.37mm × 20.30mm / 1”× 0.8” Xadow GSM Breakout Dimensions 25.37mm × 20.30mm / 1” × 0.8” Module Connection The Xadow GSM+BLE integrates a Xadow 36 Pin connector and a Xadow 11 Pin connector. As the image shows here, you can connect the Xadow GSM+BLE to Xadow GSM breakout with a Xadow 36 Pin cable, but do bear in mind that the cable has to be inserted firmly and flat, and most importantly, keep the ‘TOP’ side upwards. The Xadow 11 Pin connector have much more flexible design, you can connect the Xadow Duino and the mainboard with a Xadow 11 Pin ribbon cable in whatever way you want, again just make sure cable is firmly inserted. Control the Light with SMS! Here is an example of controlling you RGB LEDs by sending a message to your RePhone. Firstly you need to follow the instructions in the Arduino IDE for RePhone Kit to download the Arduino IDE for RePhone Kit as well as install the drivers. Then copy the following code to your Arduino IDE for RePhone. Choose the board as “RePhone” and download it with the “MTK USB Debug Port”. #include   #include   #include   #include   #include   #include     //SMS command 0 : "OFF" ‐ off display.  //SMS command 1 : "R100G0B0" ‐ red color is 100, green color is 0, blue coler is 0.  char num[20];  char buf_contex[200];      void setup()  {      Serial.begin(115200);      Serial.print("Ws2812 test.\r\n");  }    void loop()  {      unsigned long rgb_color;        if(LSMS.available())      {          LSMS.remoteNumber(num, 20);          LSMS.remoteContent(buf_contex, 50);            Serial.println("Get new sms: ");            Serial.print("Number:");          Serial.println(num);            Serial.print("Content:");          Serial.println(buf_contex);            if(strcmp("OFF", buf_contex) == 0)          {              Serial.print("RGB off.\r\n");              LWs2812.monochrome(5, 0, 1);          }          else          {              if(StingFind(buf_contex, "R", 1))              {                  if(StingFind(buf_contex, "G", 1))                  {                      if(StingFind(buf_contex, "B", 1))                      {                          Serial.print("RGB flag is find.\r\n");                          char color_r[4] = {0};                          char color_g[4] = {0};                          char color_b[4] = {0};                            sscanf(buf_contex + 1,"%[^G]", color_r);                          sscanf(buf_contex,"%*[^G]G%[^B]", color_g);                          sscanf(buf_contex,"%*[^B]B%[^\0]", color_b);                            rgb_color = atol(color_r)*256*256 + atol(color_g)*256 + atol(color_b);                            Serial.print("rgb color is ");                          Serial.println(rgb_color);                          delay(100);                          LWs2812.monochrome(5, rgb_color, 0);                          delay(100);                          LWs2812.monochrome(5, rgb_color, 0);                      }                  }              }          }      }  }    int StingFind(char* string, char* find, int number)  {      char* pos = string;      char* p = string;      int count = 0;        while(number > 0)      {          pos = strstr(p, find);          if(pos == 0)return ‐1;            while(p  0x80 || *p
113060002 价格&库存
很抱歉,暂时无法提供与“113060002”相匹配的价格&库存,您可以联系我们找货
