Grove - 16 Channel PWM Driver (PCA9685)
The Grove - 16-Channel PWM Driver is based on NXP PCA9685, which is a 16Channel, 12 bit I2C PWM driver. This board can drive up to 16 servos with the external
power supply. You can control this board with Arduino easily via the I2C Grove
interface. In addition, you can use this board as a LED controller.
Feature
1 MHz Fast-mode Plus compatible I2C-bus
6 hardware address pins allow 62 PCA9685 devices to be connected to the same I2C-bus
Low standby current
Noise filter on SDA/SCL inputs
Specification
Item
Value
MCU Operating Voltage
3.3V / 5V
PWM Supply Voltage
2.3V ~ 5.5V
Tolerant Inputs
5.5V
Output Current on pin LEDn
25mA
Ground Supply Current
400mA
Operating temperature
‐40~85Ԩ
Interface
I2C
I2C address
0x7f
Typical applications
Servos driver
RGB or RGBA LED driverHardware Overview
Pin Out
Warning
Hot swap is not supported, you may want to disconnect arduino from the power source
before any replacement or change.
Hardware Detail
I2C Interface
This board uses the I2C interface to allow the on-board MCU to communicate with the
host computer.
GND: connect this module to the system GND
VCC: you can use 5V or 3.3V for this module
SDA: I2C serial data
SCL: I2C serial clock
Power In
Provide 5V DC power for the servo.
PWM Out
There are 16 groups of Pins(1 - 16) on this board, each group of pins contains one
PWM signal pin, one 5V power supply pin and one pin for ground.
Working Principle
Platforms Supported
Arduino
Raspberry Pi
BeagleBone
Wio
LinkIt ONE
Getting Started
Play With Arduino
Hardware
Materials required
Seeeduino V4.2
Base Shield
Grove ‐ 16‐Channel PWM
Driver
LED
Note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use
the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not
sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the
Grove cable, you can click here to buy.
3 You also need prepare at least 2 jumper wires, in case you do not have, you can
click here to buy.
Step 1. Connect red LED to GND and P1 by using dual-female jumper wires.
Step 2. Connect the Grove - 16-Channel PWM Driver to port I2C of Grove-Base
Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
Note
In this example for LED, as we are not using pin '5V' in output group we do not need to
power up the power input port. If you want to use servo, you need to connect the 5V pin
to the power pin of servo, and you need to offer external power for Power In port.
If you want to use servo, you can connect as shown below:
Software
Attention
If this is the first time you work with Arduino, we strongly recommend you to see Getting
Started with Arduinobefore the start.
Step 1. Download the Grove-16-Channel_PWM_Driver-PCA9685 Library from
Github.
Step 2. Refer to How to install library to install library for Arduino.
Step 3. Restart the Arduino IDE. Open the example, you can open it in the following
three ways:
a. Open it directly in the Arduino IDE via the path: File → Examples
→Seeed_PCA9685 → led.
b. Open it in your computer by click the basic_demo.ino which you can find in the
folder XXXX\Arduino\libraries\Seeed_PCA9685\examples\led\led.ino, XXXX
is the location you installed the Arduino
IDE.
c. Or, you can just click the icon
in upper right corner of the code block to copy
the following code into a new sketch in the Arduino IDE.
1#include "PCA9685.h"
2#include
3
4PCA9685 led;
5
6
7void setup()
8{
9 // join I2C bus (I2Cdev library doesn't do this automatically)
10 Wire.begin();
11 Serial.begin(9600);
12 led.init(0x7f);
13 // Set freq to 100Hz, range from 24Hz~1526hz
14 led.setFrequency(100);
15
16 for (int i=1;i
很抱歉,暂时无法提供与“108020102”相匹配的价格&库存,您可以联系我们找货
