Grove - Optocoupler Relay (M281).md
This module is a bi-directional SPSD(single-pole, single-throw), normally open solid
state relay(SSR). The Grove Optocoupler Relay (M281) offers very low on-resistance,
which allowing a high load current rating.
Unlike the other TRIAC SSR in our website, this relay is based on MOSFET, so it can
carry both AC load and DC load. If you need to use a SSR with the DC load, this is what
you want!
Features
Low on-resistance(0.5Ω MAX.)
1A continuous load current
60V load voltage rating
Low input control current(3mA TYP.)
High input-to-output isolation(1.5kV MIN.)
Applications
Automated Test Equipment
Meter reading systems
Medical equipment
Battery monitoring
Multiplexers
Specification
Parameter
Value
Supply voltage
3.3V / 5V
Operating temperature
‐40 – 85Ԩ
Storage temperature
‐ 55°C – 125°C
Blocking voltage
60 V
Continuous load current
1A
Leakage current
0.2 uA(TYP.)
1 uA(Max.)
On‐Resistance
0.5 Ω(TYP.)
0.7 Ω(Max.)
Isolation resistance
100 GΩ
Turn‐On time
1.4 ms(TYP.)
5 ms(Max.)
Turn‐Off time
0.2 ms(TYP.)
2 ms(Max.)
Interface
Digital
Table 1.General Specification
Hardware Overview
Pinout
Figure 1. Pinout
Platforms Supported
Arduino
Raspberry Pi
BeagleBone
Wio
LinkIt ONE
Getting Started
Play With Arduino
Hardware
Materials required
Seeeduino V4.2
Base Shield
Grove ‐ Optocoupler Relay
(M281)
Red LED
In addition, you can consider our new Seeeduino Lotus M0+, which is equivalent to the
combination of Seeeduino V4.2 and Baseshield.
Note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use
the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not
sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the
Grove cable, you can click here to buy.
Hardware Connection
Step 1. Plug Grove - Base Shield into Seeeduino.
Step 2. Connect the Grove - Optocoupler Relay (M281) to the D5 port of the Base
Shield.
Step 3. Connect the LED and the Grove - Optocoupler Relay (M281) to
the 3.3V and GND pin of the Grove - Base Shield.(Please refer to the figure below)
Step 4. Connect Seeeduino to PC via a USB cable.
Figure 2. Pinout, please make sure connect to the 3.3v pin, 5v will damage this LED.
Software
Attention
If this is the first time you work with Arduino, we strongly recommend you to see Getting
Started with Arduinobefore the start.
Step 1. Copy the following code into a new sketch in the Arduino IDE
1const int Pinout = 5;
2
3void setup() {
4 pinMode(Pinout, OUTPUT);
5 Serial.begin(9600);
6}
7
8void loop() {
9
10 digitalWrite(Pinout, HIGH);
11 delay(500);
12 digitalWrite(Pinout, LOW);
13 delay(500);
14}
Step 2. Upload the demo. If you do not know how to upload the code, please check How to
upload code.
Success
If everything goes well, we will see the LED flashing.
Tech Support
Please submit any technical issue into our forum or drop mail to techsupport@seeed.cc
http://wiki.seeedstudio.com/Grove‐Optocoupler_Relay‐M281/4‐15‐19
很抱歉,暂时无法提供与“101020603”相匹配的价格&库存,您可以联系我们找货
