113030004
    SEEED(矽递科技)
    WIFI SHIELD (FI250)
113030004 数据手册
2013/10/08 18:30 1/10 WizFi250 Datasheet WizFi250 Datasheet Introduction The WizFi250 is a small size wireless module. The WizFi250 provides for the highest-level integration, featuring 802.11b/g and 802.11n. It includes a 2.4 GHz WLAN CMOS power amplifier (PA) that meets the output power requirements of most handheld systems. Along with the integrated power amplifier, the WizFi250 also includes integrated transmit and receive baluns, further reducing the overall solution cost. The small size & low profile physical design make it easier for system design to enable high performance wireless connectivity without space constrain. Hardware WAPI acceleration engine, AES, TKIP, WPA and WPA2 are supported to provide the latest security requirement on your network. For the software and driver development, WIZnet provides extensive technical document and reference software code for the system integration. 2013/08/28 09:43 · ssekim Features ● ● ● ● ● ● ● ● ● ● ● ● ● ● Single band 2.4GHz IEEE 802.11b/g/n Integrated RF power amplifier Supports wireless data rates up to 65Mbit/s 1MB Flash Memory, 128KB SRAM, 1MB Serial Flash Supports per packet Rx Antenna diversity Low power consumption & excellent power management performance extend battery life. Small size suitable for low volume system integration. Easy for integration into mobile and handheld device with flexible system configuration. 2.412-2.484 GHz two SKUs for worldwide market. Lead Free design which supporting Green design requirement, RoHS Compliance. Device Package : 28×20 mm (17×20 mm) Serial Interface : UART, SPI Powerful Web server provides Soft AP Enough memory retention Wi-Fi Security (WEP, WPA/WPA2PSK) L2 Switching OTA(Over The Air F/W Upgrading) ❍ ❍ ❍ ● 2013/08/28 09:42 · ssekim Block diagram The WizFi250 module is designed based on WiFi block and MCU block . It supports generic SPI, UART interface to connect the WLAN to the host processor. A simplified block diagram of the WizFi250 module is depicted in the Fig. below. Wiki site - http://wizwiki.net/wiki/ Last update: 2013/10/04 15:54 products:wizfi250:wizfi250ds:start http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250ds:start 2013/08/28 09:47 · ssekim Pin description Pin map http://wizwiki.net/wiki/ Printed on 2013/10/08 18:30 2013/10/08 18:30 3/10 WizFi250 Datasheet Pin description Pin Number Pin Define Type Description 1 GND Groud 2 VBAT_WL I Battery supply input 3 VBAT_WL I Battery supply input 4 GND - Ground 5 VDDIO_3V3_WL I Digital I/O supply. 6 GND - Ground 7 NC - – 8 NC - – 9 NC - – 10 NC - – 11 NC - – 12 NC - – 13 GND - Ground 14 NC - – 15 GND - Ground 16 NC - – 17 NC - – 18 NC - – 19 NC - – 20 NC - – 21 SPI_MISO I/O SPI_MISO 22 SPI_SCK I/O SPI CLOCK 23 SPI_MOSI I/O SPI_MOSI 24 SPI_SS I/O SPI_SS 25 GND - Ground 26 VDD_3V3 I Power supply for I/O and the internal regulator 27 VDD_3V3 I Power supply for I/O and the internal regulator 28 GND - Ground 29 UART2_RTS I/O Active-low request-to-send signal for UART2 interface 30 UART2_CTS I/O Active-low clear-to-send signal for UART2 interface 31 UART2_RXD I/O Serial data input for UART2 interface 32 UART2_TXD I/O Serial data output for UART2 interface 33 NC - – 34 RESET I RESET pin (Active Low) 35 NC - – 36 NC - – 37 GND - Ground 38 VBAT_MICRO I Power supply when VDD_3V3 is not present. 39 GND - Ground 40 GPIO1 I/O GPIO1 pin 41 BOOT_MODE I BOOT MODE pin (Active low) 42 FUNCTION I FUNCTION pin (Active Low) 43 GPIO5 I/O GPIO5 pin 44 GPIO6 I/O GPIO6 pin Wiki site - http://wizwiki.net/wiki/ Last update: 2013/10/04 15:54 products:wizfi250:wizfi250ds:start http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250ds:start 45 46 47 48 49 50 GPIO7 GPIO8 GPIO9 Wi-Fi_LED MODE_LED GPIO14 I/O I/O I/O I/O I/O I/O 51 JTAG_TRST I 52 JTAG_TDO I/O 53 JTAG_TDI I/O 54 JTAG_TMS I 55 JTAG_TCK I 56 57 58 59 GND GND GND GND - 60 SLEEP_CLK I GPIO7 pin GPIO8 pin GPIO9 pin Wi-Fi_LED pin MODE_LED pin GPIO14 pin For normal operation, if JTAG is not used, this pin can be left unconnected (NC) For normal operation, if JTAG is not used, this pin can be left unconnected (NC) For normal operation, if JTAG is not used, this pin can be left unconnected (NC) For normal operation, if JTAG is not used, this pin can be left unconnected (NC) For normal operation, if JTAG is not used, this pin can be left unconnected (NC) Ground Ground Ground Ground Input pin for optional high- precision 32.768kHz Clock(Sleep Clock). Active-low request-to-send signal for UART1 interface Active-low clear-to-send signal for UART1 interface Serial data input for UART1 interface Serial data output for UART1 interface Ground 61 UART1_RTS I/O 62 UART1_CTS I/O 63 UART1_RXD I/O 64 UART1_TXD I/O 65~73 GND 2013/08/28 10:41 · ssekim Technical specification Absolute maximum rating Supply Power Max +3.6 Volt NonOperating Temperature - 40° to 85° Celsius Voltage ripple +/- 2% Max Values not exceeding Operating voltage Recommendable operation condition Temperature, humidity The WizFi250 has to withstand the operational requirements as listed in the table below. Operating Temperature -20° to 85° Celsius Humidity range Max 95%, Non condensing, relative humidity * The maximum operating ambient temperature range can up to 85°, but exposure to absolute-maximum-rated conditions may cause performance degradation and affect device reliability. So we recommend -20° to 75° for the best performance. Voltage Power supply for the WizFi250 module will be provided by the host via the power pins. http://wizwiki.net/wiki/ Printed on 2013/10/08 18:30 2013/10/08 18:30 5/10 WizFi250 Datasheet Symbol Parameter Min Typ. Max Unit VBAT_WL power supply for WizFi250 3.0 3.3 3.6 V VDDIO_3V3_WL host Interface power supply 3.0 3.3 3.6 V VBAT_MICRO backup operating voltage 3.0 3.3 3.6 V VDD_3V3 power supply for MCU 3.0 3.3 3.6 V Current consumption The WizFi250 on operation output current consumption : WiFi mode Typ. Max. (802.11n) (RMS) Normal mode Not Associated 14 mA 18 mA Normal mode Associated 67 mA 69 mA Associated Normal mode 32 mA 65 mA (IEEE Power Save mode) Associated Stop mode 14 mA 17 mA (IEEE Power Save mode) Stop mode Not Associated 3 mA 23 mA MCU mode The WizFi250 on TX mode output current consumption : (Typical spec is defined @3.3V 25℃ ; MAX. spec is defined @3.0V 70℃) Current Consumption Typ. Max. Tx output power @16.5 dBm on 11b 1M 385 mA 430 mA Tx output power @ 16.5 dBm on 11b 11M 370 mA 410 mA Tx output power @ 15 dBm on 11g 6M 345 mA 380 mA Tx output power @ 13 dBm on 11g 54M 290 mA 320 mA Tx output power @ 14.5 dBm on 11n MCS0 315 mA 350 mA Tx output power @ 12 dBm on 11n MCS7 265 mA 295 mA The WizFi250 on RX mode current consumption : (Typical spec is defined @3.3V 25℃; MAX. spec is defined @3.0V 70℃) Current Consumption Typ. Max. Rx @ 11b 1M 120 mA 150 mA Rx @ 11b 11M 120 mA 150 mA Rx @ 11g 6M 120 mA 150 mA Rx @ 11g 54M 120 mA 150 mA Rx @ 11n MCS0 120 mA 150 mA Rx @ 11n MCS7 120 mA 150 mA Wireless specifications The WizFi250 complies with the following features and standards; Features Description WLAN Standards IEEE 802 11 b/g/n Antenna Connecter Port One printed antenna, one U.FL connector for external antenna Frequency Band 2.400 GHz ~ 2.484 GHz Number of Sub Channels CH1 to CH14 Wiki site - http://wizwiki.net/wiki/ Last update: 2013/10/04 15:54 products:wizfi250:wizfi250ds:start http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250ds:start Modulation DSSS, CCK, OFDM, BPSK, QPSK,16QAM, 64QAM 11b 1, 2, 5.5, 11 (Mbps) Supported data rates 11g 6, 9, 12, 18, 24, 36, 48, 54 (Mbps) 11n HT20 MCS0(6.5Mbps) to HT20 MCS7(65Mbps) Specifications of WiFi’s output power, evm, sensitivity The WizFi250 WiFi output power as list in the table below: Characteristics Typ. Criteria Unit 1M 16.5 +/- 1.5 dBm RF Average Output Power, 802.11b CCK Mode 11M 16.5 +/- 1.5 dBm 6M 15 +/- 1.5 dBm RF Average Output Power, 802.11g OFDM Mode 54M 13 +/- 1.5 dBm MCS0 14.5 +/- 1.5 dBm RF Average Output Power, 802.11n OFDM Mode MCS7 12 +/- 1.5 dBm WiFi TX EVM follow the IEEE spec that as list in the table below: Characteristics IEEE Spec Unit @1 Mbps -10 dB RF Average Output EVM (11b) @11 Mbps -10 dB @6 Mbps -5 dB RF Average Output EVM (11g) @54 Mbps -25 dB @ MCS0 -5 dB RF Average Output EVM (11n) @ MCS7 -28 dB The WizFi250 Wi-Fi sensitivity as list in the table below: Receiver Characteristics Typ. Max. Unit PER
113030004 价格&库存
很抱歉,暂时无法提供与“113030004”相匹配的价格&库存,您可以联系我们找货
