8.06.18 J-LINK TARGET SUPPLY ADAPTER 数据手册
SEGGER - The Embedded Experts - J-Link Debug Probes - Adapters - Target Supply Ad...
J-Link Debug Probes
Adapters
Target Supply Adapter
J-Link Target Supply Adapter
The J-Link Target Supply Adapter provides an adjustable supply voltage to the target board. It has a standard 20-pin 0.1" socket towards
the J-Link debug probe and a standard 20-pin 0.1" header on the target side and can directly be inserted between the J-Link and the debug
cable maintaining a 1:1 connection of all debug signals. The supply voltage to the target is provided through pin 19 of the debug cable.
The supply voltage is fixed to 3.3V and can be adjusted in the range 3.6V down to 0.8V by means of changing a single resistor on the
adapter (soldering required, resistor package SMD 0805). Since the J-Link Target Supply Adapter is fed by the J-Link its current capability is
limited to 400mA. Furthermore the current capability depends on the chosen target voltage. Example target voltage/output current
combinations:
3,6V/400mA*
3,3V/400mA*(default)
2,5V/300mA**
1,8V/200mA**
1,0V/150mA**
Notes:
* To operate the J-Link Target Supply Adapter with the battery powered Flasher Portable adjustment of an additional resistor
(SMD 1206) might be required. See block diagram for details.
** Exceeding these current values will damage the adapter. To increase maximum output current see block diagram.
The J-Link Supply Adapter is compatible with J-Link BASE J-Link PRO, J-Link ULTRA+, J-Link PLUS , Flasher Portable and Flasher ARM.
Block diagram of the J-Link Target Supply Adapter
https://www.segger.com/jlink-target-supply-adapter.html
4/13/2017
8.06.18 J-LINK TARGET SUPPLY ADAPTER 价格&库存
很抱歉,暂时无法提供与“8.06.18 J-LINK TARGET SUPPLY ADAPTER”相匹配的价格&库存,您可以联系我们找货
