ARDUINO SHIELD SGPC3_SHTC3
    SENSIRION(盛思锐)
    SENSOR-4P_2X2MM_EP_SM
    SGPC3,SHTC3 空气质量,湿度,温度 传感器 Arduino 平台评估扩展板
ARDUINO SHIELD SGPC3_SHTC3 数据手册
Datasheet SGPC3 Indoor Air Quality Sensor for TVOC Measurements  Ultra-low power gas sensor for indoor air quality applications  Outstanding long-term stability  Ultra-low power consumption: 0.065 mA at 1.8V  I2C interface with TVOC output signal  Very small 6-pin DFN package: 2.45 x 2.45 x 0.9 mm3  Tape and reel packaged, reflow solderable Product Summary The SGPC3 is a digital ultra-low power gas sensor designed for mobile and battery-driven indoor air quality applications. Sensirion’s CMOSens® technology offers a complete sensor system on a single chip featuring a digital I2C interface, a temperature-controlled micro-hotplate and a preprocessed indoor air quality signal. The sensing element features an unmatched robustness against contamination by siloxanes present in real-world applications enabling a unique long-term stability and low drift. The very small 2.45 x 2.45 x 0.9 mm3 DFN package and its ultra-low power consumption make the SGPC3 perfectly suited for mobile and wearable applications. Sensirion’s state-of-the-art production process guarantees high reproducibility and reliability. Tape and reel packaging, together with suitability for standard SMD assembly processes make the SGPC3 predestined for high-volume applications. Block Diagram Figure 1 Functional block diagram of the SGPC3. www.sensirion.com Version 1.0 – May 2020 – D1 1/19 1 Sensor Performance 1.1 Gas Sensing Performance Parameter Signal Values Measurement range1 Ethanol signal 0 ppm to 1000 ppm Specified range Ethanol signal 0.3 ppm2 to 30 ppm Comments The specifications below are defined for this measurement range. The specified measurement range covers the gas concentrations expected in indoor air quality applications. Accuracy is defined as Relative accuracy3 Ethanol signal see Figure 2 typ.: 15% of meas. value c - cset cset with c the measured concentration and cset the concentration set point. The concentration c is determined by sref - sout c = cref ∙ exp ( ) 512 with sout: Ethanol signal output at concentration c sref: Ethanol signal output at concentration cref = 0.18 ppm Long-term drift4 Ethanol signal see Figure 3 typ.: 1.3% of meas. value Change of accuracy over time: Siloxane accelerated lifetime test5 Resolution Ethanol signal 0.2 % of meas. value Resolution of Ethanol signal output in relative change of the measured concentration Sampling time Ethanol signal Low power mode: 2s Ultralow power mode: 30s The on-chip baseline algorithm has been optimized for these sampling rates. The sensor shows best performance when used with this sampling rate. Table 1 Gas sensing performance. Specifications are at 25°C, 50% RH and typical VDD. All parameters are determined for the low-power operation mode with one measurement every 2s. The sensors have been operated for at least 24h before the first characterization. Exposure to ethanol and H2 concentrations up to 1000 ppm have been tested. For applications requiring the measurement of higher gas concentrations please contact Sensirion. 2 ppm: parts per million. 1 ppm = 1000 ppb (parts per billion) 3 90% of the sensors will be within the typical accuracy tolerance, >99% are within the maximum tolerance. 4 The long-term drift is stated as change of accuracy per year of operation. 5 Test conditions: operation in 250 ppm Decamethylcyclopentasiloxane (D5) for 200h simulating 10 years of operation in an indoor environment. 1 www.sensirion.com Version 1.0 – May 2020 – D1 2/19 Accuracy Ethanol signal Figure 2 Typical and maximum accuracy tolerance for the low-power operation mode in % of measured value at 25°C, 50% RH and typical VDD. The sensors have been operated for at least 24h before the characterization. Long-term drift Ethanol signal Figure 3 Typical and maximum long-term drift in % of measured value for the low-power operation mode at 25°C, 50% RH and typical VDD. The sensors have been operated for at least 24h before the first characterization. 1.2 Air Quality Signal Air quality signal TVOC is calculated from Ethanol measurements using internal conversion and baseline compensation algorithms (see Figure 4). Signal Processing Baseline compensation & Signal conversion Figure 4 Simplified version of the functional block diagram (compare Figure 1) showing the signal paths of the SGPC3. www.sensirion.com Version 1.0 – May 2020 – D1 3/19 Specifications of air quality signals are shown in Table 2. Parameter Output range Signal Values Comments TVOC signal 0 ppb to 60000 ppb Maximum possible output range. The gas sensing performance is specified for the measurement range as defined in Table 1 TVOC signal Range Resolution 0 ppb - 2008 ppb 1 ppb 2008 ppb – 11110 ppb 6 ppb 11110 ppb – 60000 ppb 32 ppb Low power mode: 2s Sampling interval TVOC signal Ultra-low power mode: 30s The on-chip baseline algorithm has been optimized for these sampling rates. The sensor shows best performance when used with this sampling rate. Table 2 Air quality signal specifications. 1.3 Recommended Operating and Storage Conditions Gas Sensing Specifications as detailed in Table 1 are guaranteed only when the sensor is stored and operated under the recommended conditions. Prolonged exposure to conditions outside these conditions may accelerate aging. The recommended temperature and humidity range for operating the SGPC3 is 5–55 °C and 4–30 g m−3 absolute humidity, respectively (see Figure 5 for the corresponding translation into relative humidity). It is recommended to store the sensor in a temperature range of 5–30 °C and below 30 g m−3 absolute humidity (see Figure 6 for the corresponding translation into relative humidity). The sensor must not be exposed towards condensing conditions (i.e., >90 % relative humidity) at any time. To ensure a stable performance of the SGPC3, conditions described in the document SGP Handling Instructions have to be met. Please also refer to the Design-in Guide for optimal integration of the SGPC3 into the final device. Figure 5 Recommended relative humidity and temperature for operating the SGPC3. www.sensirion.com Figure 6 Recommended relative humidity and temperature for storing the SGPC3. Version 1.0 – May 2020 – D1 4/19 2 Electrical Specifications Parameter Min. Typ. Max. Unit Comments Supply voltage VDD 1.62 1.8 1.98 V Minimal voltage must be guaranteed also for the maximum supply current specified in this table. Hotplate supply voltage VDDH 1.62 1.8 1.98 V Supply current in measurement mode6 48.8 mA The measurement mode is activated for 40 ms by sending an “sgpc3_measure_tvoc”, “sgpc3_measure_raw” or “sgpc3_measure_tvoc_and_raw” command. After 40 ms, the sensor will be set into sleep mode. Specified at 25°C and typical VDD. Average supply current low power mode 0.98 mA Average supply current with one measurement every 2s. Average supply current ultra-low power mode 0.065 mA Average supply current with one measurement every 30s. Sleep current 2 10 μA LOW-level input voltage -0.5 0.3*VDD V HIGH-level input voltage 0.7*VDD VDD+0.5 V 0.05*VDD V LOW-level output voltage 0.2*VDD V Communication I 2C Vhys hysteresis of Schmitt trigger inputs Digital 2-wire interface, (open-drain) at 2mA sink current fast mode. Table 3 Electrical specifications. 3 Interface Specifications The SGPC3 comes in a 6-pin DFN package, see Table 4. Pin Name Comments 1 VDD Supply voltage 2 VSS Ground 1 3 SDA Serial data, bidirectional 2 4 R Connect to ground (no electrical function) 5 VDDH Supply voltage, hotplate 6 SCL Serial clock, bidirectional 3 S GP C 6 5 AX 89 4 Table 4 Pin assignment (transparent top view). Dashed lines are only visible from the bottom. 6 A 20% higher current is drawn during 5ms on VDDH after entering the measurement mode. www.sensirion.com Version 1.0 – May 2020 – D1 5/19 Figure 7 Typical application circuit (for better clarity in the image, the positioning of the pins does not reflect the positions on the real sensor). The electrical specifications of the SGPC3 are shown in Table 3. The power supply pins must be decoupled with a 100 nF capacitor that shall be placed as close as possible to pin VDD – see Figure 7. The required decoupling depends on the power supply network connected to the sensor. We also recommend VDD and VDDH pins to be shorted. SCL is used to synchronize the communication between the microcontroller and the sensor. The SDA pin is used to transfer data to and from the sensor. For safe communication, the timing specifications defined in the I 2C manual7 must be met. Both SCL and SDA lines are open-drain I/Os with diodes to VDD and VSS. They should be connected to external pull-up resistors. To avoid signal contention, the microcontroller must only drive SDA and SCL low. The external pull-up resistors (e.g. Rp = 10 kΩ) are required to pull the signal high. For dimensioning resistor sizes please take bus capacity and communication frequency into account (see for example Section 7.1 of NXPs I2C Manual for more details7). It should be noted that pull-up resistors may be included in I/O circuits of microcontrollers. The die pad or center pad is electrically connected to GND. Hence, electrical considerations do not impose constraints on the wiring of the die pad. However, for mechanical stability it is recommended to solder the center pad to the PCB. 4 Absolute Minimum and Maximum Ratings Stress levels beyond those listed in Table 5 may cause permanent damage to the device. These are stress ratings for the electrical components only and functional operation of the device at these conditions cannot be guaranteed. Exposure to the absolute maximum rating conditions for extended periods may affect the reliability of the device. Parameter Rating Supply voltage VDD -0.3 V to +2.16 V Supply voltage VDDH -0.3 V to +2.16 V Storage temperature range -40 to +125°C Operating temperature range -40 to +85°C Humidity Range 10% - 95% (non-condensing) ESD HBM 2 kV ESD CDM 500 V Latch up, JESD78 Class II, 125°C 100 mA Table 5 Absolute minimum and maximum ratings. Please refer to Handling and Assembly Guideline for Sensirion Gas Sensors on Sensirion webpage for full documentation. 7 http://www.nxp.com/documents/user_manual/UM10204.pdf www.sensirion.com Version 1.0 – May 2020 – D1 6/19 5 Timing Specifications 5.1 Sensor System Timings Default conditions of 25°C and 1.8 V supply voltage apply to values in the table below, unless otherwise stated. The timings refer to the power up and reset of the ASIC part and do not reflect the usefulness of the readings. Parameter Symbol Condition Min. Typ. Max. Unit Comments Power-up time tPU After hard reset, VDD ≥VPOR - 0.4 0.6 ms - Soft reset time tSR After soft reset - 0.4 0.6 ms - Table 6 System timing specifications. 5.2 Communication Timings Default conditions of 25 °C and 1.8 V supply voltage apply to values in the table below, unless otherwise stated. Parameter Symbol Conditions Min. Typ. Max. Units Comments SCL clock frequency fSCL - 0 - 400 kHz - Hold time (repeated) START condition tHD;STA After this period, the first clock pulse is generated 0.6 - - µs - LOW period of the SCL clock tLOW - 1.3 - - µs - HIGH period of the SCL clock tHIGH - 0.6 - - µs - Set-up time for a repeated START condition tSU;STA - 0.6 - - µs - SDA hold time tHD;DAT - 0 - - ns - SDA set-up time tSU;DAT - 100 - - ns - SCL/SDA rise time tR - - - 300 ns - SCL/SDA fall time tF - - - 300 ns - SDA valid time tVD;DAT - - - 0.9 µs - Set-up time for STOP condition tSU;STO - 0.6 - - µs - Capacitive load on bus line CB - 400 pF - Table 7 Communication timing specifications. t 1 / t t t R F 7 0 3 0 SCL t D A t 7 0 3 0 SDA t D A t F SDA t R 7 0 3 0 Figure 8 Timing diagram for digital input/output pads. SDA directions are seen from the sensor. Bold SDA lines are controlled by the sensor; plain SDA lines are controlled by the micro-controller. Note that SDA valid read time is triggered by falling edge of preceding toggle. www.sensirion.com Version 1.0 – May 2020 – D1 7/19 6 Operation and Communication The SGPC3 supports I2C fast mode. For detailed information on the I2C protocol, refer to NXP I2C-bus specification7. All SGPC3 commands and data are mapped to a 16-bit address space. Additionally, data and commands are protected with a CRC checksum to increase the communication reliability. The 16-bit commands that are sent to the sensor already include a 3-bit CRC checksum. Data sent from and received by the sensor is always succeeded by an 8-bit CRC. In write direction it is mandatory to transmit the checksum, since the SGPC3 only accepts data if it is followed by the correct checksum. In read direction it is up to the master to decide if it wants to read and process the checksum. SGPC3 Hex. Code I2C address 0x58 Table 8 I2C device address. The typical communication sequence between the I2C master (e.g., a microcontroller in a host device) and the sensor is described as follows: 1. The sensor is powered up, communication is initialized 2. The I2C master periodically requests measurement and reads data, in the following sequence: a. I2C master sends a measurement command b. I2C master waits until the measurement is finished, either by waiting for the maximum execution time or by waiting for the expected duration and then poll data until the read header is acknowledged by the sensor (expected durations are listed in Table 10) c. I2C master reads out the measurement result 6.1 Power-Up and Communication Start The sensor starts powering-up after reaching the power-up threshold voltage VDD,Min specified in Table 3Table 6. After reaching this threshold voltage, the sensor needs the time tPU to enter the idle state. Once the idle state is entered it is ready to receive commands from the master. Each transmission sequence begins with a START condition (S) and ends with a STOP condition (P) as described in the I2Cbus specification. 6.2 Measurement Communication Sequence A measurement communication sequence consists of a START condition, the I2C write header (7-bit I2C device address plus 0 as the write bit) and a 16-bit measurement command. The proper reception of each byte is indicated by the sensor. It pulls the SDA pin low (ACK bit) after the falling edge of the 8th SCL clock to indicate the reception. With the acknowledgement of the measurement command, the SGPC3 starts measuring. When the measurement is in progress, no communication with the sensor is possible and the sensor aborts the communication with a XCK condition. After the sensor has completed the measurement, the master can read the measurement results by sending a START condition followed by an I2C read header. The sensor will acknowledge the reception of the read header and responds with data. The response data length is listed in Table 10 and is structured in data words, where one word consists of two bytes of data followed by one byte CRC checksum. Each byte must be acknowledged by the microcontroller with an ACK condition for the sensor to continue sending data. If the sensor does not receive an ACK from the master after any byte of data, it will not continue sending data. After receiving the checksum for the last word of data, an XCK and STOP condition have to be sent (see Figure 10). The I2C master can abort the read transfer with a XCK followed by a STOP condition after any data byte if it is not interested in subsequent data, e.g. the CRC byte or following data bytes, in order to save time. Note that the data cannot be read more than once, and access to data beyond the specified amount will return a pattern of 1s. 6.3 Measurement Commands The available measurement commands of the SGPC3 are listed in Table 10. www.sensirion.com Version 1.0 – May 2020 – D1 8/19 Set Power Mode The SGPC3 offers two operation modes with different power consumptions and sampling intervals. The low-power mode with 1mA average current and 2s sampling interval and the ultra-low power mode with 0.065mA average current and 30s sampling interval. By default, the SGPC3 is using the low-power mode. The sensor can be switched to the ultra-low power operation mode by sending the “sgpc3_set_power_mode” command followed by 2 data bytes (MSB first) with a value of “0x0000” and the corresponding CRC byte. The “sgpc3_set_power_mode” command has to be sent before the “sgpc3_tvoc_init_continuous” command (Figure 9). A restart of the sensor (power-up or soft reset) or a “sgpc3_set_power_mode” command followed by a “0x0001” switches the sensor back to the default low-power operation mode. It is recommended to test the two modes on different SGPC3 sensors, as switching the power mode back and forth with the same sensor will impact sensor accuracy. Air Quality Signal The SGPC3 uses a dynamic baseline compensation algorithm and on-chip calibration parameters to provide a preprocessed total VOC signal (TVOC) air quality signal. Sending the “sgpc3_tvoc_init_continuous” commands initializes and starts the air quality measurement. In addition, the “sgpc3_tvoc_init_continuous” command is used to accelerate the switch-on time of the SGPC3. After sending the “sgpc3_tvoc_init_continuous” command, the SGPC3 is operated in a high power operation mode until the first “sgpc3_measure_tvoc” command is sent. During this time interval the hotplate of the SGPC3 is operated continuously with a supply current as indicated in Table 3 (supply current during measurements). For air quality measurements the “sgpc3_measure_tvoc” command is used. The “sgpc3_measure_tvoc” command has to be sent in regular intervals of 2s for the low-power operation mode or 30s for the ultra-low power operation mode to ensure proper operation of the dynamic baseline compensation algorithms and the specified power consumption. The sensor responds with 2 data bytes (MSB first) and 1 CRC byte for the preprocessed air quality signal which corresponds to a TVOC concentration in ppb. For the first 20s after the first “sgpc3_measure_tvoc” command the sensor is in an initialization phase during which a “sgpc3_measure_tvoc” command returns a fixed value of 0 ppb. After every power-up or soft reset, a new “sgpc3_tvoc_init_continuous” command has to be sent. The command sequence after start-up for initializing and repeating measurements is illustrated in Figure 9. Figure 9 Command sequence for starting the SGPC3 in the low-power and the ultra-low-power mode. An example implementation of a generic driver including recommended time intervals for the accelerated switch-on phase can be found in the document SGPC3_driver_integration_guide. Set and Get Baseline The SGPC3 provides the possibility to read and write the baseline value of the baseline compensation algorithm. This feature is used to save the baseline in regular intervals on an external non-volatile memory and restore it after a new power-up or soft reset of the sensor. The command “sgpc3_get_tvoc_baseline” returns the baseline value. The sensor responds with 2 data bytes (MSB first) and 1 CRC byte. This value should be stored on the external memory. After a power-up or soft reset, the baseline of the baseline compensation algorithm can be restored by sending first an “sgpc3_tvoc_init_continuous” command followed by a “sgpc3_set_tvoc_baseline” command with the baseline value as a parameter. The baseline value is specific for the operation mode. “sgpc3_get_tvoc_baseline” returns the baseline value for the operation mode set by the “sgpc3_set_power_mode” command. www.sensirion.com Version 1.0 – May 2020 – D1 9/19 Inceptive Baseline for TVOC measurements8 The inceptive baseline offers an individually calibrated starting reference to the dynamic baseline compensation algorithm. Thereby the feature yields a better TVOC concentration accuracy for the very first start-up under bad air condition. This results in a better user experience especially when accuracy is required. Please note, that the application of this feature is solely limited to the very first start-up period of an SGP sensor. Furthermore, it is limited to the TVOC signal output. The command “sgpc3_get_tvoc_inceptive_baseline” reads the precalibrated reference point from the sensor HW and “sgpc3_set_tvoc_baseline” activates the inceptive baseline. Sensor Signals The command “sgpc3_measure_raw” is intended for part verification and testing purposes. It returns the sensor raw signal for ethanol (Sout_ETOH). The ethanol signal is used as input for the on-chip calibration and baseline correction algorithm as shown in Figure 9. The command performs a measurement to which the sensor responds with 2 data bytes (MSB first) and 1 CRC byte (see Figure 10). The Ethanol signal can be used to calculate gas concentrations c relative to a reference concentration cref by sref - sout c = cref ∙ exp ( ) 512 with sout = sout_EtOH and sref the Ethanol signal output at the corresponding reference concentration cref_EtOh. The command “sgpc3_measure_tvoc_and_raw” returns the sensor raw signal (Sout_ETOH) and the TVOC air quality signal. This command can be used in place of the “sgpc3_measure_tvoc” or the “sgpc3_measure_raw” command. The command performs a measurement to which the sensor responds with 2 data bytes (MSB first) and 1 CRC byte (see Figure 10) each for the Ethanol signal and the TVOC air quality signal in the order Ethanol signal (Sout_ETOH) and TVOC air quality signal. Humidity Compensation The SGPC3 features an on-chip humidity compensation for the air quality signal and the sensor raw signal (Ethanol signal). To use the on-chip humidity compensation an absolute humidity value from an external humidity sensor like the SHTxx is required. Using the “sgpc3_set_absolute_humidity” command, a new humidity value can be written to the SGPC3 by sending 2 data bytes (MSB first) and 1 CRC byte. The 2 data bytes represent humidity values as a fixed-point 8.8bit number with a minimum value of 0x0001 (=1/256 g/m3) and a maximum value of 0xFFFF (255 g/m3 + 255/256 g/m3). For instance, sending a value of 0x0F80 corresponds to a humidity value of 15.50 g/m3 (15 g/m3 + 128/256 g/m3). After setting a new humidity value, this value will be used by the on-chip humidity compensation algorithm until a new humidity value is set using the “sgpc3_set_absolute_humidity” command. Restarting the sensor (power-on or soft reset) or sending a value of 0x0000 (= 0 g/m3) disables the humidity compensation until a new humidity value is sent. Absolute humidity values dV in unit g/m3 can be calculated by the following formula: RH 17.62 ∙ T ∙ 6.112 ∙ exp ( ) 243.12 + T 100% dv (T, RH) = 216.7 ∙ [ ], 273.15+T with temperature T and relative humidity RH. Example: Inserting T = 25°C and RH = 50% in above formula results in the absolute humidity dV = 11.8 g/m3. 8 The inceptive baseline feature is available for SGPC3 sensors with feature set 6 and later. www.sensirion.com Version 1.0 – May 2020 – D1 10/19 Feature Set The SGPC3 features a versioning system for the available set of measurement commands and on-chip algorithms. This so called feature set version number can be read out by sending a “sgpc3_get_feature_set_version” command. The sensor responds with 2 data bytes (MSB first) and 1 CRC byte (see Table 9). This feature set version number is used to refer to a corresponding set of available measurement commands as listed in Table 10. Most significant byte (MSB) Bit 1 2 3 4 Product type SGPC3: 1 Least significant byte (LSB) 5 6 7 Reserved for future use 8 9 10 11 0 12 13 14 15 16 Product version Table 9 Structure of the SGP feature set number. Please note that the last 5 bits of the product version (bits 12-16 of the LSB) are subject to change. This is used to track new features added to the SGP multi-pixel platform. Measure Test The command “sgpc3_measure_test” which is included for integration and production line testing runs an on-chip self-test. In case of a successful self-test the sensor returns the fixed data pattern 0xD400 (with correct CRC). Feature Set Command 0x1006 Hex. Code Parameter length, including CRC [bytes] Response length, including CRC [bytes] Max. measurement duration [ms] sgpc3_tvoc_init_continuous 0x20ae - - 10 sgpc3_measure_tvoc 0x2008 - 3 50 sgpc3_set_power_mode 0x209f 3 - 10 sgpc3_get_tvoc_baseline 0x2015 - 3 10 sgpc3_set_tvoc_baseline 0x201e 3 - 10 sgpc3_set_absolute_humidity 0x2061 3 - 10 sgpc3_measure_test9 0x2032 - 3 220 sgpc3_get_feature_set_version 0x202f - 3 10 sgpc3_measure_raw 0x204d - 3 50 sgpc3_measure_tvoc_and_raw 0x2046 - 6 50 sgpc3_get_tvoc_inceptive_baseline 0x20b3 3 3 10 Table 10 Measurement commands. The «sgpc3_measure_test» command is intended for production line testing and verification only. It should not be used after having issued an “sgpc3_tvoc_init_continuous” command. For the duration of the « sgpc3_measure_test » command, the sensor is operated in measurement mode with a supply current as specified in Table 3. After the command, the sensor is in sleep mode. 9 www.sensirion.com Version 1.0 – May 2020 – D1 11/19 6.4 Soft Reset A sensor reset can be generated using the “General Call” mode according to I2C-bus specification. It is important to understand that a reset generated in this way is not device specific. All devices on the same I2C bus that support the General Call mode will perform a reset. The appropriate command consists of two bytes and is shown in Table 11. Hex. Code Address byte 0x00 Second byte 0x06 Reset Command using the General Call address 0x0006 2 3 4 5 6 7 8 9 1 ACK 1 S General Call Address 2 3 4 5 6 7 Reset Command 8 9 ACK Command General Call 2nd byte st General Call 1 byte Table 11 Reset through the General Call address (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.). 6.5 Get Serial ID The readout of the serial ID register can be used to identify the chip and verify the presence of the sensor. The appropriate command structure is shown in Table 12. After issuing the measurement command and sending the ACK Bit the sensor needs the time tIDLE = 0.5ms to respond to the I2C read header with an ACK Bit. Hence, it is recommended to wait tIDLE =0.5ms before issuing the read header. The get serial ID command returns 3 words, and every word is followed by an 8-bit CRC checksum. Together the 3 words constitute a unique serial ID with a length of 48 bits. The ID returned with this command are represented in the big endian (or MSB first) format. Command Hex. Code Get Serial ID 0x3682 4 5 6 I2C write header 7 8 9 W 1 2 3 4 5 6 7 Command MSB 8 9 10 11 12 13 14 15 16 17 18 Command LSB ACK 3 ACK 2 I2C Address ACK 1 S 16-bit command Table 12 Get serial ID command. www.sensirion.com Version 1.0 – May 2020 – D1 12/19 6.6 Checksum Calculation The 8-bit CRC checksum transmitted after each data word is generated by a CRC algorithm. Its properties are displayed in Table 13. The CRC covers the contents of the two previously transmitted data bytes. To calculate the checksum only these two previously transmitted data bytes are used. Property Value Name CRC-8 Width 8 bit Protected Data read and/or write data Polynomial 0x31 (x8 + x5 + x4 + 1) Initialization 0xFF Reflect input False Reflect output False Final XOR 0x00 Examples CRC (0xBEEF) = 0x92 Table 13 I2C CRC properties. 6.7 Communication Data Sequences Figure 10 Communication sequence for starting a measurement and reading measurement results. 7 Quality 7.1 Environmental Stability The qualification of the SGPC3 was performed based on the JEDEC JESD47 qualification test method. 7.2 Material Contents The device is fully RoHS and WEEE compliant, e.g., free of Pb, Cd, and Hg. 8 Device Package SGPC3 sensors are provided in a DFN (dual flat no leads) package with an outline of 2.45 × 2.45 × 0.9 mm3 and a terminal pitch of 0.8 mm. The circular sensor opening of maximally 1.6 mm diameter is centered on the top side of the package. The sensor chip is assembled on a Ni/Pd/Au plated copper lead frame. Sensor chip and lead frame are over-molded by a black, epoxybased mold compound. Please note that the side walls of the package are diced and therefore the lead frame sidewall surfaces are not plated. SGPC3 8.1 Moisture Sensitivity Level The Moisture Sensitivity Level classification of the SGPC3 is MSL1, according to IPC/JEDEC J-STD-020. www.sensirion.com Version 1.0 – May 2020 – D1 13/19 8.2 Traceability All SGPC3 sensors are laser marked for simple identification and traceability. The marking on the sensor consists of the product name and a 4-digit, alphanumeric tracking code. This code is used by Sensirion for batch-level tracking throughout production, calibration, and testing. Detailed tracking data can be provided upon justified request. The pin-1 location is indicated by the keyhole pattern in the light-colored central area. See Figure 11 for illustration. S GP C AX 89 Figure 11 Laser marking on SGPC3. The pin-1 location is indicated by the keyhole pattern in the light-colored central area. The bottom line contains a 4-digit alphanumeric tracking code 8.3 Package Outline 2.45 0.3x45o 0.9 0.35 1.7 2.45 0.8 0.2* 0.4 1.25 Figure 12 Package outlines drawing of the SGPC3 with nominal values. Dimensions are given in millimeters. * The die pad shows a small recess in the bottom left part. * These dimensions are not well defined and given as a reference only. 8.4 Landing Pattern Figure 13 shows the PCB landing pattern. The landing pattern is understood to be the metal layer on the PCB, onto which the DFN pads are soldered. The solder mask is understood to be the insulating layer on top of the PCB covering the copper traces. It is recommended to design the solder mask as a Non-Solder Mask Defined (NSMD) type. For solder paste printing it is recommended to use a laser-cut, stainless steel stencil with electro-polished trapezoidal walls and with 0.125 to 0.150 mm stencil thickness. The length of the stencil apertures for the I/O pads should be the same as the PCB pads. However, the position of the stencil apertures should have an offset of 0.1 mm away from the package center, as indicated in Figure 13. The die pad aperture should cover 70 – 90 % of the die pad area, resulting in a size of about 1.05 mm x 1.5 mm. For information on the soldering process and further recommendation on the assembly process please contact Sensirion. www.sensirion.com Version 1.0 – May 2020 – D1 14/19 Figure 13 Recommended landing pattern. 8.5 Soldering Instructions Standard reflow soldering ovens may be used for soldering. The sensors are designed to withstand a soldering profile according to IPC/JEDEC J-STD-020. Peak temperatures of TP = 245 °C during up to tp = 30 seconds for Pb-free assembly in IR/Convection reflow ovens (see Figure 14) are recommended. In addition, we also recommend a maximum ramp-down rate of < 4 °C/s. Figure 14 Soldering profile according to JEDEC standard. Recommended conditions are TP =245 °C and tP ≤ 30 sec for Pb-free assembly, TL < 220 °C and tL < 150 s. Ramp-up rate < 3 °C/s and ramp-down rate < 4 °C/s. It is recommended not to use vapor phase soldering to avoid potential contamination of the sensor. Please refer to Handling and Assembly Guideline for Sensirion Gas Sensors on Sensirion webpage for full documentation. www.sensirion.com Version 1.0 – May 2020 – D1 15/19 9 Tape & Reel Package Ø1.5 +.1 /-0.0 4.00 2.00 ±.05 SEE Note 2 0.30 ±.05 Ø1.00 MIN 1.75 ±.1 4.00 SEE Note 1 A 5.50 ±.05 SEE NOTE 2 R 0.2 MAX. B0 B 12.0 +0.3/-0.1 A R 0.25 TYP. K0 A0 A0 = 2.75 B0 = 2.75 K0 = 1.20 SECTION A - A TOLERANCES - UNLESS NOTED 1PL ±.2 2PL ±.10 NOTES: 1. 10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE ±0.2 2. POCKET POSITION RELATIVE TO SPROCKET HOLE MEASURED AS TRUE POSITION OF POCKET, NOT POCKET HOLE 3. A0 AND B0 ARE CALCULATED ON A PLANE AT A DISTANCE "R" ABOVE THE BOTTOM OF THE POCKET DETAIL B Figure 15 Technical drawing of the packaging tape with sensor orientation in tape. Header tape is to the right and trailer tape to the left on this drawing. Dimensions are given in millimeters. 10 Ordering Information Use the part names and product numbers shown in the following table when ordering the SGPC3 multi-pixel gas sensor. For the latest product information and local distributors, visit www.sensirion.com. Part Name Tape & Reel Size Product Number SGPC3, TAPE ON REEL, 2500 PCS 2500 1-101647-01 Table 14 SGPC3 ordering options www.sensirion.com Version 1.0 – May 2020 – D1 16/19 Revision History Date May, 2020 www.sensirion.com Version 1.0 Page(s) – Changes – Version 1.0 – May 2020 – D1 17/19 Important Notices Warning, Personal Injury Do not use this product as safety or emergency stop devices or in any other application where failure of the product could result in personal injury. Do not use this product for applications other than its intended and authorized use. Before installing, handling, using or servicing this product, please consult the data sheet and application notes. Failure to comply with these instructions could result in death or serious injury. If the Buyer shall purchase or use SENSIRION products for any unintended or unauthorized application, Buyer shall defend, indemnify and hold harmless SENSIRION and its officers, employees, subsidiaries, affiliates and distributors against all claims, costs, damages and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if SENSIRION shall be allegedly negligent with respect to the design or the manufacture of the product. ESD Precautions The inherent design of this component causes it to be sensitive to electrostatic discharge (ESD). To prevent ESD-induced damage and/or degradation, take customary and statutory ESD precautions when handling this product. See application note “ESD, Latchup and EMC” for more information. Warranty SENSIRION warrants solely to the original purchaser of this product for a period of 12 months (one year) from the date of delivery that this product shall be of the quality, material and workmanship defined in SENSIRION’s published specifications of the product. Within such period, if proven to be defective, SENSIRION shall repair and/or replace this product, in SENSIRION’s discretion, free of charge to the Buyer, provided that:  notice in writing describing the defects shall be given to SENSIRION within fourteen (14) days after their appearance;  such defects shall be found, to SENSIRION’s reasonable satisfaction, to have arisen from SENSIRION’s faulty design, material, or workmanship;  the defective product shall be returned to SENSIRION’s factory at the Buyer’s expense; and  the warranty period for any repaired or replaced product shall be limited to the unexpired portion of the original period. This warranty does not apply to any equipment which has not been installed and used within the specifications recommended by SENSIRION for the intended and proper use of the equipment. EXCEPT FOR THE WARRANTIES EXPRESSLY SET FORTH HEREIN, SENSIRION MAKES NO WARRANTIES, EITHER EXPRESS OR IMPLIED, WITH RESPECT TO THE PRODUCT. ANY AND ALL WARRANTIES, INCLUDING WITHOUT LIMITATION, WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, ARE EXPRESSLY EXCLUDED AND DECLINED. SENSIRION is only liable for defects of this product arising under the conditions of operation provided for in the data sheet and proper use of the goods. SENSIRION explicitly disclaims all warranties, express or implied, for any period during which the goods are operated or stored not in accordance with the technical specifications. SENSIRION does not assume any liability arising out of any application or use of any product or circuit and specifically disclaims any and all liability, including without limitation consequential or incidental damages. All operating parameters, including without limitation recommended parameters, must be validated for each customer’s applications by customer’s technical experts. Recommended parameters can and do vary in different applications. SENSIRION reserves the right, without further notice, (i) to change the product specifications and/or the information in this document and (ii) to improve reliability, functions and design of this product. Copyright © 2020 by SENSIRION. CMOSens® is a trademark of Sensirion. All rights reserved. www.sensirion.com Version 1.0 – May 2020 – D1 18/19 Headquarters and Subsidiaries Sensirion AG Laubisruetistr. 50 CH-8712 Staefa ZH Switzerland Sensirion Inc., USA phone: +1 312 690 5858 info-us@sensirion.com www.sensirion.com Sensirion Korea Co. Ltd. phone: +82 31 337 7700~3 info-kr@sensirion.com www.sensirion.com/kr phone: +41 44 306 40 00 fax: +41 44 306 40 30 info@sensirion.com www.sensirion.com Sensirion Japan Co. Ltd. phone: +81 3 3444 4940 info-jp@sensirion.com www.sensirion.com/jp Sensirion China Co. Ltd. phone: +86 755 8252 1501 info-cn@sensirion.com www.sensirion.com/cn Sensirion Taiwan Co. Ltd phone: +886 3 5506701 info@sensirion.com www.sensirion.com To find your local representative, please visit www.sensirion.com/distributors 1 www.sensirion.com Version 1.0 – May 2020 – D1 19/19
ARDUINO SHIELD SGPC3_SHTC3 价格&库存
很抱歉,暂时无法提供与“ARDUINO SHIELD SGPC3_SHTC3”相匹配的价格&库存,您可以联系我们找货
