SKHC1-071-06-C-T100-NS-TF00-ALO 数据手册
SKHC1-071-06-C Specifications
Ordering Guide
Sample Part Number: SKHC1-071-06-C-T100-NS-T0-F0-Al0
Chip Type
Solder Type
Sealant
Thickness
Tolerance
Flatness
Tolerance
Ceramic Type
Ceramic
Surface
SKHC1-071-06-C
T100
NS
T0
F0
AlO
SKHC1-071-06-C
71 couples,
6A max
T100
BiSn (up to
138C)
NS
No Sealant
T0
±0.1 mm
F0
±0.05
mm
AlO
Alumina (96%
white)
None
Performance Metrics
Hot Side Temp
Cat Logic
(°C)
TE Dimensions (mm)
(°C)
(Watts)
(Amps)
(DC
Volts)
(Ω)
A
B
C
D
SKHC1-071-06-C
27
72
35.6
6.4
8.9
1.06
22
22
3.8
150
SKHC1-071-06-C
50
81
41.1
6.8
9.6
1.06
22
22
3.8
150
Notes:
1.
2.
3.
All performance values fall within ±10% tolerance of tested data and/or models.
Dimensions are typical and subject to change based on exact configuration ordered.
Contact Sheetak at info@sheetak.com for additional performance data, chip options or customization
Chip Dimensions
Notes:
1.
2.
3.
Please see the Ordering Guide for flatness and thickness tolerances.
Ceramic face with part number is the cold side and wires are soldered on the hot side.
Some TECs may have a porch design or wires soldered on the side.
Rev A 04/20
1
Performance Curves @ TH= 27°C
QC (W)
Performance Curves @ TH= 50°C
QC (W)
dT (°C)
V (V)
V (V)
dT (°C)
Rev A 04/20
dT (°C)
dT (°C)
2
SKHC1-071-06-C-T100-NS-TF00-ALO 价格&库存
很抱歉,暂时无法提供与“SKHC1-071-06-C-T100-NS-TF00-ALO”相匹配的价格&库存,您可以联系我们找货
